odd IC test reading, have 8 ics on bottom and 3 on top of board all give odd reading.
    • 12122
    • U.S.
    odd IC test reading, have 8 ics on bottom and 3 on top of mainboard all give odd reading, get a volt reading on two of the pins but theres always a reading on one of the 3 pins that reads in mv, which is millivotes I guess, you think I need to maybe replace all of these, Thanks.
    Re: odd IC test reading, have 8 ics on bottom and 3 on top of board all give odd read
    Are you talking about a Y-buffer board?
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      A Vague Clue on what the device actually is would be good!
      Is this a TV, a Video-Recorder or what? --What does this board do in that device and what are the IC's supposed to do??
      TELEFIX
        • 12122
        • U.S.
        sorry guys, its my samsung lcd tv mainboard, I'll grab a pic. http://www.shopjimmy.com/samsung-bn9...main-board.htm
          • 12122
          • U.S.
          acording to datasheet, ic101 should read 2.5v-ground, 1.8-input, 3.3-output, I'm getting 1.79-G, 4.7mv-Input, 3.34-output, looks like the input is way off?, and every dam one of these 11 ics has one reading in mv, strange.
            • 12122
            • U.S.
            not exactly sure Alistair E, but I think they regulate voltage.
              • 12122
              • U.S.
              I think ic102 should have the same reading, ie, 2.5-G, 1.8-input, 3.3-output, but it reads 5.4mv-G, 13.3v-input, 7.9v-output. don't know, should the input ever be bigger than the output?, thanks.
                • 12122
                • U.S.
                on at least one of these ics on the bottom of board, the ground on one reads 2.5 on top and the same ground at bottom starts at 22mvs goes to 200 mvs flashes ol then starts back at 22mvs does the same thing over, strange two very different readings on the exact same ground?
                • mmartell
                  • Oct 2013
                  • 3189
                  The input voltage may not be there until the mainboard sends pson to power supply and the power supply in turn turns on the main board. Not enough information here to go by.
                    • 12122
                    • U.S.
                    tested with tv on, all boards hooked up, tested ones on bottom of board, by holding mainboard on its edge, so it wasnt screwed down.
                    • mmartell
                      • Oct 2013
                      • 3189
                      Yes but obviously this tv isn't working so first you need to know if the power supply voltages are all there at the connector.
                      Also when you are holding the board on edge it isn't grounded to the chassis like it has to be as you make no mention of using a clip to ground it.
                        • 12122
                        • U.S.
                        when the tv is on its just a snowy picture, can't see the menu, acted the same when it was screwed down, only had it on its edge to test ics on bottom.
                          • 12122
                          • U.S.
                          power supply voltages all correct with all boards hooked up, seems to be mainboard, trying to narrow down to component, but it no easy.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Search "how to test a voltage regulator" and post the info back as per instructions. Assuming of course these are voltage regulators you are talking about.
                            • CapLeaker
                              Leaking Member
                              • 8118
                              So you are getting a input signal, but no menu or any OSD? Is it a lightning strike special?
                                • 12122
                                • U.S.
                                not sure CapLeaker, no background on it, the menu may be there, the snow changes slightly when I toggle thru source, but the snow is too dense to make out anything, so I can't tell if theres a menu.
                                  • 12122
                                  • U.S.
                                  oh crap, I forgot to throw up a pic, MY BAD.
                                    • 12122
                                    • U.S.
                                    the ics I'm looking at are ic101, ic102, ic1702, and 7 or 8 more on the bottom. http://www.shopjimmy.com/samsung-bn9...main-board.htm
                                      • 12122
                                      • U.S.
                                      I KNOW how to test these ics, its the reading that are screwed up.
                                        • 12122
                                        • U.S.
                                        I probably know more about tvs than you do martel, SO DON'T TALK DOWN TO ME, COMPRENDO?
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Technomancer
                                          Nintendo 2DS SD Card Reader issue. Problem on the clock line?
                                          by Technomancer
                                          I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
                                          Here is what I have done so far:
                                          -Tried SD card in another 2DS and on PC, works great.
                                          -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
                                          -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
                                          06-07-2022, 09:01 PM
