LG LCD 42LD750 Backlight flashes 4 times, then tv off.
  • hopkok
    • Oct 2014
    • 181
    • Slovakia
    #41
    Re: LG LCD 42LD750 Backlight flashes 4 times, then tv off.
    [QUOTE=hopkok;925636]
    Originally posted by torentino
    Hi sir, how much increase? 30 Ohms or more?
    Increased to 25 Ohm each, and working, thank you
    • discman
      • Nov 2013
      • Lithuania
      #42
      [QUOTE=torentino;n1341397]Re: LG LCD 42LD750 Backlight flashes 4 times, then tv off.
      Originally posted by Adriatic
      My same Tv does exactly the same. I increased value of R403 and 404, 20ohm, 1W by few more ohms. Those are shunts for ccfl current, it worked for me. he set is on now almost 2 years without issues.
      WOW man, you are GENIUS!!!
      I have replaced four resistors R401, R402, R403, R404 (originaly measures around 20ohm) with 27ohm (2W) resistors. The TV is back to life!
      • provider22
        samsung UA32d4OO RED LIGHT FLASHES 3 TIMES
        by provider22
        11-19-2025, 02:45 AM
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • Egidio85
        Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
        by Egidio85
        Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
        the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
        the fan does not start.
        I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
        any advice on what to check?
        06-10-2025, 05:00 AM
      • Davy no Caps
        Vestel 17MB82S EEprom dump required
        by Davy no Caps
        First time trying to fix a TV for a friend, it's a Bush DLED32165HD.
        Power Board - 17IPS11
        Mainboard - 17MBS82S
        Panel - VES315WNDB-02
        Red blinking standby light is on steady, press power button on remote and light flashes 7 times then stays steady, press power on remote again light flashes 10 times and then goes off.
        Checked all the voltages on the power board inc backlight circuit, they all read ok and are stable. Backlights tested with backlight tester and all work fine (2 strips x11LED on each).
        No picture, backlight or sound just blinking...
        06-06-2025, 03:22 PM
      • esqmooo
        HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
        by esqmooo
        I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
        03-07-2025, 05:55 AM
