LG LCD 42LD750 Backlight flashes 4 times, then tv off.
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by Egidio85Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
the fan does not start.
I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?
any advice on what to check? -
by Davy no CapsHi all,
First time trying to fix a TV for a friend, it's a Bush DLED32165HD.
Power Board - 17IPS11
Mainboard - 17MBS82S
Panel - VES315WNDB-02
Red blinking standby light is on steady, press power button on remote and light flashes 7 times then stays steady, press power on remote again light flashes 10 times and then goes off.
Checked all the voltages on the power board inc backlight circuit, they all read ok and are stable. Backlights tested with backlight tester and all work fine (2 strips x11LED on each).
No picture, backlight or sound just blinking... -
by esqmoooHi,
I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.03-07-2025, 05:55 AM -
by ayecrutHi everyone,
I have picked up an LG brand television, manufactured in 2014. The model is LG-49UB850V / LG-49UB850V ZD (Link).
When I tried to start it the first time it didn't work, the screen remained black and the red LED blinked 3 times or just stayed on all the time. After moving it and plugging it in somewhere else, it restarted once or twice, but since then it hasn't started with the same symptoms.
Other information:
- The physical button that turns on the TV without the remote doesn't seem to work. Nothing happens when you press it, we can only... - Loading...
