26PFL5322/12 screen freeze + white horizontal lines
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    When the TV is turned on, it is possible to move around in menus. About 8-10 seconds after the screen turning on, white horizontal lines appear, first on top 2/3 of the screen and about 5 seconds later bottom 1/3 of the screen turns white for a couple of seconds. At this point, screen is frozen (so about 20 seconds after the screen starts showing picture). Those horizontal white lines keep appearing and disappearing.
    This is all I know about this TV.
    My question is: Probably just a faulty t-con, right?
  • sordids999
    • May 2013
    • 2158
    • uk
    Re: 26PFL5322/12 screen freeze + white horizontal lines
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      I was asking because I do not own this TV yet. I was thinking about buying it if it could possibly be fixed by replacing t-con, cause this t-con is quite cheap.
      • kdaniel
        Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
        by kdaniel
        As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
        There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
        After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
        Left...
        11-16-2022, 09:23 AM
      • ggil44
        Sony XBR-65X750D Horizontal lines bottom of screen
        by ggil44
        Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
        05-30-2023, 07:51 PM
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • Runlinc
        Samsung QE50Q60TAU - Horizontal screen lines
        by Runlinc
        Hi everyone, the tv was in a continuous reboot cycle. To get the best screen image i can I taped the VGH and VSS pins on the left side buffer board joining ribbon.
        I am left with a good image apart from the black horizontal lines that I cannot get rid of.
        I cannot find anything on the buffer boards that has shorted.
        Do you think there is anything i can do to eliminate the lines, or are they caused by an internal panel short and the image cannot be impoved.
        Many thanks for your assistance
        05-14-2024, 07:40 AM
