UE40D5000 red led blinking (PSU, Main board and T-con changed)
  • labo555
    • May 2015
    • 14
    • Italia
    Re: UE40D5000 red led blinking (PSU, Main board and T-con changed)
    help me please
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Ok Psu is good then, have you tried disconnecting the Tcon from the Mb and powering the set up ?
      • labo555
        • May 2015
        • 14
        • Italia
        hello thank you for answering ..
        I have tried to connect tcon but the problem remains
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Ok so the Mb is at fault here.
          • labo555
            • May 2015
            • 14
            • Italia
            ok what can I do? I have to replace it, or I can try to repair it
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              Bet its the Bga solder, best to replace.
              • pgram
                • Apr 2016
                • 37
                If it is the BGA solder on the main board's CPU, you could try heating the CPU to melt/reflow the solder as a workaround. It is not a guaranteed fix and there is a good chance the problem will show up again at a later date, but it is low or no cost option and may get you a few more months or more of use from the set without having to replace the whole board.
                Video examples:
                • labo555
                  • May 2015
                  • 14
                  • Italia
                  #28
                  ok thanks for the advice you have been so nice try with a reflow otherwise I will replace the main
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • TerraPhantm
                    Sony A8H to A80J mainboard upgrade possible?
                    by TerraPhantm
                    I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
                    So I decided I'd experiment a little bit.
                    I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
                    When...
                    08-15-2023, 08:10 AM
                  • x_orange90_x
                    TCL 50S535 bad tcon or panel issue?
                    by x_orange90_x
                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                    03-29-2025, 11:02 PM
                  • cheeky2
                    by cheeky2
                    05-25-2024, 03:27 AM
                  • howardc64
                    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                    by howardc64
                    • Prior owner tried a replacement main board. No difference.
                    • Samsung 2x red blinking standby LED = panel fault
                    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                    07-19-2025, 10:54 PM
