Lg 50pv350t
    Re: Lg 50pv350t
    Loose connection? Is that damaged COF OK?
    • sordids999
      • May 2013
      • 2149
      • uk
      #42
      Re: Lg 50pv350t
      not sure tom ill run and test it
      COF tom ?
        Re: Lg 50pv350t
        TCP.. sorry.
        • sordids999
          • May 2013
          • 2149
          • uk
          #44
          Re: Lg 50pv350t
          Tcp went in fine after trimming it down tv is still working fine at the moment fingers crossed
          • Shinju
            • Mar 2014
            • 1239
            Re: Lg 50pv350t
            Full screen test patterns with no lines?
            • sordids999
              • May 2013
              • 2149
              • uk
              #46
              Re: Lg 50pv350t
              https://www.youtube.com/watch?v=_VQlBSn_oYc
              yes Shinju test patterns are fine and testing the tv still now
                Re: Lg 50pv350t
                Really quite amazing considering the damage done.
                • sordids999
                  • May 2013
                  • 2149
                  • uk
                  #48
                  Re: Lg 50pv350t
                  yeah im still trying to get my head around it tom no traces of water residue on the back inside cover or the bottom casing,but speaker housing has corrosion seems to all be on the left side of the tv but i cleaned it up the best i could
                  fingers crossed but you never know
                  thanks all for your help again guys im debating if i should this on my wall but i do like my 47 inch philips ambilight though
                  • MisterAIL
                    PS5 digital / No Power / No Beep / Good power supply
                    by MisterAIL
                    Brought a non functionnal PS5. Apparently only a bad PSU...
                    No beep, nothing.
                    After some tests i found this :
                    - PSU is fine (12 volts stable)
                    - 12 volts line is shorted
                    - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                    - By the way, nothing change. No signal, no power, no beep.
                    Mesuring all rails with my workbench psu (12 volts input)
                    - 0.00 amp drawing
                    - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                    03-12-2024, 03:24 PM
                  • BTubbs200
                    Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                    by BTubbs200
                    Dell Latitude 5420 P137G
                    Board: LA-K491P REV A01
                    I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                    Board seems to have no shorts, all power rails are fine and show high resistance.
                    When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                    01-24-2025, 08:15 PM
                  • legg
                    LG 42PC3 buffer output doesn't follow YSUS
                    by legg
                    LG42PC3D -UD originally with green lamp but no display or audio.
                    Owner says was working, then went 'pop'.
                    All 5V caps bulging. replaced.
                    All PSU output voltages within spec but -Vy is low on YSUS.
                    One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                    eventually shorts DG. Replaced all 3 - -Vy now OK.
                    Y scan buffer test point does not follow YSUS output below -50V
                    Note: This unit seems to expect YSUS output to park at -Vy in between
                    drive signal pattern periods. A replacement drive signal board confirms this....
                    11-18-2021, 11:49 AM
                    MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
                    I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
                    I open it up to find non brands name capacitors in it
                    I am not sure how this switching power supply is set up
                    Could someone please explain how this power supply works
                    Here is the capacitor ESR results
                    (1) 47uf@50 volts 0.46
                    (2) 47uf@50 volts 0.45
                    New 47uf@50 volts 0.35
                    (1) 100uf@25 volts 0.34
                    (2) 100uf@25 volts 0.35
                    New 120uf@50 volts 0.08
                    (1) 220@25 volts 0.13...
                    10-21-2018, 10:02 AM
                  • stylishconsultant
                    un60j620dafxza - Samsung No Display Problem
                    by stylishconsultant
                    Hi All,
                    Need help.
                    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                    09-04-2024, 03:26 AM
