Kogan KALED463D1ZA
  • dkneyle
    • Dec 2013
    • 441
    Re: Kogan KALED463D1ZA
    Just to complete the story, yes, they assessed the TV as unrepairable and have offered a $580 credit note, or the 50 inch TV with the Innolux panel. I had thought of upgrading to their 50 inch smart TV (with LG panel) but the reviews for the TV are very ordinary. So I think I haven't got much of an option other than to go for the Innolux and just see if I can live with it. Let's face it, I had a completely defective TV, so now I'll at least have something that works.
    • tw2005
      • Oct 2011
      • 6457
      better than a total loss.
      • jagiro84
        Alienware x15 R2 no memory detected (hell repair job, 6 months later)
        by jagiro84
        Hi guys,
        its been around 5-6months since i left this board on side to rest my brain cells and now came back to try and repair it again.
        The laptop in question has issue where it gives error code on power on which is 2red and 3 blue
        In short, by Dell specs this means "Memory not detected: "
        Now one important thing the laptop would turn on fine when i leave it in the refrigerator for 5-10min and i could work\play games with it for days and months as long as i dont turn it off
        but after a while this trick stopped working as wel
        12-29-2024, 05:05 AM
      • TrueSword88
        KOGAN - KALED58RT9220SVA - Image flickering when in Energy Saving mode
        by TrueSword88
        Hi All
        I have a KOGAN 58' LCD Panel that 'flickers / pulsates' when in energy saving mode.
        I've reset the unit to factory default & rerun the initial setup but no change.
        IF I choose any other mode, example: Standard, flickering disappears.
        I've downloaded the most recent FW for this model from Kogan's website & re-flashed. This initiated a full wipe of the unit, which subsequently led to the setup all over again, however, the issue still remained - screen flickering but only when in 'energy saving' mode.
        I've taken the unit apart,...
        05-05-2023, 06:07 PM
      • TrueSword88
        Kogan - KALED65XU9220STB - Blue Vertical Line
        by TrueSword88
        Hi all.
        I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
        The line just happens to coincide with the end of COF and start of the next COF (attached).
        The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
        Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
        Hoping to fix...
        05-05-2023, 04:28 PM
      • Firentiosi
        1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
        by Firentiosi
        Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
        The issues are as follows: the...
        11-27-2024, 12:33 AM
      • Hairspring
        Screen dimmer in recent months, weird symptom: EPG screen goes bright! LG 19LD350
        by Hairspring
        In recent months the screen has been getting more and more dim. If that was all, I'd suppose the problem would be the backlight (LED? LCD?). But I've noticed this really weird symptom: switching to the EPG screen restores normal brightness! And then, even weirder, when I go back to the programme, for a moment the programme is at normal brightness and over the next 1-2 seconds it gradually dims down again.
        Last time I looked in a TV it had EHT flyback, so I'm no expert. I do sometimes repair computer monitors and power supplies, most often when there's bad caps.
        Anyhow,...
        12-04-2022, 11:18 AM
