Samsung PS50B850Y1W 50" Plasma. Green vertical bar!
  • Nicholas
    • 60
    • Kingdom of Denmark
    Hi guys
    I have a green bar on the left side of the image(see attached picture pls). I
    open the set, and remove the annoying metal bars to get to the boards at the
    bottom. Here I can see that the flat cables from the panel seems to NOT go
    into sockets, but instead looks like they are attached to the board in a
    different way..maybe glued or soldered? (see attached picture pls)
    If that bottom board is defective, does that mean that the entire panel is
    compromised? The boards on the sides have the panel flat cables in sockets!
    The bottom board says:
    Model No. 50 U SLIM LOGIC
    PCB No.: LJ41-06439A
    Rev. AA1
    PBA No.: LJ92-0169A
    Any advice would be more than welcome!!
    Thanks,
    Nicholas
  • AFajitas
    • 183
    Re: Samsung PS50B850Y1W 50" Plasma. Green vertical bar!
    Yes, if that board is bad = bad panel. But don't jump to conclusions yet. Someone more experienced should be able to chime in.
    • Nicholas
      • 60
      That was what I was afraid of. Seems weird to produce it this way.
      If it is bad component on the board I might be able to work on it 'in situ'.
      I hope someone can chime in
      • drussell
        • Nov 2014
        • 144
        That would be both "cost cutting" and "planned destruction" at their finest.
        No connectors to reduce cost and twice as many tab bonds to fail.
        • Nicholas
          • 60
          I tried to poke the board to see if there was a change, but no luck. I take it that
          a component in the area has failed. Has anyone tried to fix such a board, and what
          component could fail?
          No need to hit it with the heat gun, eh?
          • Nicholas
            • 60
            Hi again!
            Take a look at this! Attached picture. There are two holes in the ribbon cable going to the bottom board. There are not any screw holes behind it, but something has drilled into the metal. I have no idea how this happened, the previous owner says he never opened the set, and there is no logical way you could ever screw something down there.The area is covered by the metal plate that attaches to the stand.
            If I turn the cable the other way, I get two bars in a different place, blue and yellow. I thought I was in Sweden for a moment...quite a shock.
            Do you guys think this warrents getting a replacement cable? The ribbon cable is a 30cm E129545 AWM 20861 VW-1.
            Thanks,
            Nicholas
            Update: The two holes through the ribbon line up with the holes for the stand. However, none of the screws from the TV
            would be able to edge into the aluminium like this. I think the previous owner might have done it by accident, maybe during
            wall mounting or something.
            • MagicSmoke
              • Feb 2011
              • 275
              You can try to find a ribbon cable from the same model TV. The #'s on the cable are the manufacturers code for that type ribbon.
              Other ribbons with same #'s may or may not have the proper shaped connections at each end.
              It most likely is the problem.
                On some earlier Samsung LED TVs (B-series) Samsung added a warning label to the back warning the user to use the supplied screws only. The tcon was mounted behind the stand - so it was apparently very easy to damage!
                • Nicholas
                  • 60
                  I have some ribbon cables en route, I will report back when I get one installed!
                  Thanks guys!
                  Nicholas
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    I've had this happen before to a tv I picked up. Pretty sure yhe new cable will fix the issue
                      I had a far right pink bar due to damaged ribbon on a Panasonic, though that was entirely my fault in that case. Hope it fixes it for you. I quite like the ultra-slim B850 design.
                        09-07-2024, 05:50 AM
                      • Falki
                        Colorful LCD Vertical Lines on Samsung ue55es8090
                        by Falki
                        Hello there, ive recently found an older 55inch Samsung SmartTV.
                        A similar issue has been posted as well but also with no actual response ...
                        08-12-2025, 04:19 AM
                      • kotel studios
                        Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                        by kotel studios
                        Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                        In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                        08-06-2025, 02:07 AM
                      • thetonywarren
                        Samsung PN51E450 Plasma Vertical Lines
                        by thetonywarren
                        Friend of mine has a Samsung Plasma panel with some vertical lines that are starting to form on the screen.....Ive never worked on a plasma panel, so Im not sure what to look for, would this typically be a main board issue, or something else?
                        Any help would be appreciated.....Please let me know.......
                        02-14-2022, 01:23 PM
                      • afex
                        Samsung Plasma TV with vertical lines (model PN50B430P2D)
                        by afex
                        This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
                        This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
                        I have attached an image of the TV with these bars displaying....
                        11-08-2021, 09:23 PM
