Sony 40S20LI Success Story
  • Michale32086
    • Nov 2011
    • 1453
    Ironically enough, no question here.
    Just wanted to pass on a success story..
    Got in a Sony 40S20LI. When powered up, there was a high-pitched whine. There was a picture (analog snow) but the upper half of the screen was darker.. After a few seconds, the system would shut off...
    Figured it was the side boards (buffers??) that were shorted or bad. I pulled off the "blast shield" to see if I could see where the problem was...
    Lo and behold, the TV powered up and worked fine..
    So, I can only assume that the shield was shorting the upper board in some manner..
    Just passing it on, since I see a LOT of comment threads regarding Sonys...
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony 40S20LI Success Story
    Thanks much. All advice, comments successes are useful.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      I had a sony a while back that the backlight board was arcing to the chassis because that 'blast-shield' was a little bent somehow.
      Bent it back out and made sure the board had some clearance to the chassis, the set was fine then....
      TELEFIX
      • Michale32086
        • Nov 2011
        • 1453
        Yea, this one has been working fine since I posted.. {knock on wood}
        • nomoresonys
          • 12306
          • U.S.
          my sony keeps going black, whenever I send a remote signal, its like it turns off, but still steady green light, anyone have this problem before or any ideas, thanks.
          • AFajitas
            • Dec 2014
            • 183
            I love when the problem is an easy fix, congrats.
            • Michale32086
              • Nov 2011
              • 1453
              Thanx
              I have a saying around my place..
              "Sometimes you get the bear, sometimes the bear gets you."
              • Carlos#2003%
                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                by Carlos#2003%
                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                02-15-2024, 07:52 PM
              • spleenharvester
                Whirlpool PACF212HP W portable air conditioner, upper fan only turns slowly.
                by spleenharvester
                I just acquired this portable aircon, history unknown. Its behaviour is quite strange:
                • When turned on and placed into cooling mode, the upper fan (cold air out) just spins slowly. The compressor and lower fan do not run.
                • If the device is then placed into heating mode and then back into cooling mode, the lower fan and compressor kick in and start cooling, but the upper fan still only spins slowly.
                • If the device is placed into fan-only mode, the upper fan does not respond to low/medium/high speed toggles - just keeps running slowly.
                • Display and buttons all behave normally aside from the
                06-27-2025, 07:49 PM
              • dkneyle
                Sony KDL-46HX850 Can't upgrade/update firmware
                by dkneyle
                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                09-25-2024, 10:44 PM
                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 05:27 AM
                Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                09-06-2024, 05:30 AM
