Just A General "Does This Look Blown To You??" Question
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Just A General "Does This Look Blown To You??" Question
    Originally posted by drussell
    As long as it is a direct-drive, oil-less type compressor (most small compressors are this type) and the hose has not been used on an traditional oil-lubricated compressor or with a line oiler you should be fine.
    Around here the air duster cans are WAY too expensive. A couple cans of that and you might as well buy yourself a small compressor.
    Thats exactly what I did £5 for a 500ml can, I brought a small ball compressor for £10 been using it for 2 years never looked back.
      Hm, Poundland sell 200ml for £1 where I live. I use it pretty much as freeze spray only though.
      • Michale32086
        • Nov 2011
        • 1453
        Yea, the air compressor I use is a small portable unit.. Cans of air run about $6 here at our local Walmart.. With some of the dust buildup I have seen, 2 cans to clean it is not outside the realm of possibility..
        Tom66, you can use canned air as a freeze spray?? I thought about that but thought it might do some damage.. Plus the fumes of it get in my mouth and tastes horrible...
        "WARNING: TICKETS ARE NOT MEANT TO BE TAKEN INTERNALLY"
        "See kids! Because of me, they have a warning!!"
        -Homer Simpson
        • drussell
          • Nov 2014
          • 144
          Yeah, a typical can of air duster held upside-down will do liquid withdrawl and act as decent freeze spray in a pinch.
          Not quite as good as "real" freeze spray but most of the time it works just fine for most purposes.
          • Michale32086
            • Nov 2011
            • 1453
            Good ta know...
            Thanx
            • cmlewis89
              LG 47LB5DF blown power supply board
              by cmlewis89
              Hi folks,
              I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
              09-03-2024, 07:50 PM
            • drscoot
              HP X360 convertible battery blown fuse error, not charging
              by drscoot
              HP Modelnumber: 14-dh0061nb​
              This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
              The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
              I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
              And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
              All these 3 batteries are charging...
              12-15-2023, 05:54 AM
            • w00pz
              Identify blown component on HP ENVY X360 13-arxxxxx, Motherboard G1 13 AMD X360 18740-1 448.0GA03.0011
              by w00pz
              I have blown a component on HP Envy x360 with motherboard G1 13 AMD X360 18740-1 448.0GA03.0011.
              Unfortunately there are no schematics available and the component was so blown the marking weren't readable.
              I have marked it with a red circle in the attached photos - sorry for the mediocre quality I was too much in a rush.
              Hope someone will be able to identify the component.
              Many thanks for your help!
              Edit: High-res picture added on a normal board (not mine)...
              11-08-2025, 02:48 PM
            • MrzPdlch
              Blown fuses on Gigabyte GTX 980TI 6GB
              by MrzPdlch
              Hey everyone,
              I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
              Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
              Find some pictures of the actual GPU together with a picture of how it should look like.
              I also wonder whther it might be a problem that there...
              03-10-2024, 04:14 PM
            • cheeky2
              Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
              by cheeky2
              This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
              I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
              Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
              06-15-2025, 05:12 AM
