I am assuming that if one is not sure whether a cap is blown or not, it's likely a good idea to swap it out...
Just A General "Does This Look Blown To You??" Question
Tags: None
Re: Just A General "Does This Look Blown To You??" Question
Is this a Hitachi plasma power supply? The 100V caps bulging is a common and well known issue with these.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
It IS a Hitachi... Seems to work OK which surprised me. I thought for sure those were blown...Comment
I have an Hitachi plasma my self, I'm still getting around to fixing it needing a buffer board but from what I remember from my research about these particular caps is when they start bulging, they produce an instability which can take out the lower/upper buffer board, someone somewhere said something about it being a higher voltage is produced but I can't back that idea up, needless to say a change is probably a good idea.Comment
I was just about to type the same reply. Consider yourself lucky if you have those two caps bulging with both buffers still functional. Every one of these I've encountered with the caps bulging has 1 or both buffers blown. It will happen if the caps aren't changed. Just a matter of time.I have an Hitachi plasma my self, I'm still getting around to fixing it needing a buffer board but from what I remember from my research about these particular caps is when they start bulging, they produce an instability which can take out the lower/upper buffer board, someone somewhere said something about it being a higher voltage is produced but I can't back that idea up, needless to say a change is probably a good idea.Comment
Good points all.. Thanx for all the replies. Much appreciated...Comment
Yea, I already took my air compressor to it.. What a mess..Comment
Let's say, for the sake of a discussion, that I ignored the great advice I received and left the (apparently) blown caps in and ran the TV all night...
Let's further postulate that, when I came in the next morning, shocker of shocks, the TV had died...
What boards did I likely blow??
I did replace the caps (day late/dollar short comes to mind) but the TV still won't come on.. I hit the master power button and the RED standby light comes on and it immediately goes to BLUE which is labeled ON.
I hear a distinct relay CLICK when the master power button is pushed and a faint relay click a few seconds after the light goes BLUE..
Nothing appears obviously blown, but I know enough to know that doesn't mean much...
Where should I look first??
For the record, this is a Hitachi P50T501Comment
Buffers and Y-sustain, usually. Maybe Y-sustain survives?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
More tough love.
"A man who carries a cat by the tail learns something he can learn in no other way."
Mark Twain
DON'T FIX IT. Put it up somewhere you can see it daily as a reminder for taking shortcuts and ignoring the advice of posts 5, 6 and 7.Last edited by retiredcaps; 02-04-2015, 05:50 PM.--- begin sig file ---
--- end sig file ---Comment
Touche'
Never ignore badcaps I learnt that the hard way several years ago, maybe you will learn from this not to ignore them ;(Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
They are also usless, I use a small ball compressor that generates air as it runs only cost £10 works better than a tank compressor and crappy cans of air.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
As long as it is a direct-drive, oil-less type compressor (most small compressors are this type) and the hose has not been used on an traditional oil-lubricated compressor or with a line oiler you should be fine.
Around here the air duster cans are WAY too expensive. A couple cans of that and you might as well buy yourself a small compressor.Comment
by cmlewis89Hi folks,
I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...12 Photos -
by drscootHP Modelnumber: 14-dh0061nb
This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
All these 3 batteries are charging...2 Photos -
by w00pzI have blown a component on HP Envy x360 with motherboard G1 13 AMD X360 18740-1 448.0GA03.0011.
Unfortunately there are no schematics available and the component was so blown the marking weren't readable.
I have marked it with a red circle in the attached photos - sorry for the mediocre quality I was too much in a rush.
Hope someone will be able to identify the component.
Many thanks for your help!
Edit: High-res picture added on a normal board (not mine)...2 Photos -
by MrzPdlchHey everyone,
I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
Find some pictures of the actual GPU together with a picture of how it should look like.
I also wonder whther it might be a problem that there...3 Photos -
by cheeky2This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets... - Loading...
