LG 46LD550 flickering, shaky, horizontal lines
  • bbadger
    • Jan 2015
    • US
    The TV is about 4 years old and just started having this problem. When it is first turned on after being off for awhile, the screen is all horizontal lines that are flickering and shaky. After the TV has been on for 10 minutes or so, the problem slowly disappears until the picture is normal. Does this seem like a TCON board issue or something else.
    This isn't my video but this YouTube video shows what the picture looks like. https://www.youtube.com/watch?v=Dr3hkj6Apcc
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4543
    • Italy - Milan
    Re: LG 46LD550 flickering, shaky, horizontal lines
    I think you have to open up the tv and try unplug the lvds cable, clean the flat connector to the tcon and reinsert.
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • mrsith
      Samsung UE70TU7100 - flickering horizontal lines
      by mrsith
      Hello again good souls.
      Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
      I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and...
      02-13-2023, 05:36 AM
    • reessi
      ACER BM320 Monitor - Horizonal Flickering Lines After a While
      by reessi
      The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
      They are black on the right and gradually fade to nothing on the far left.
      They start either after 5 mins or up to 2 hours after so annoying for testing.
      They flicker continuously very fast! With a slight pause milli-second every second.
      Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
      I tested each half by removing the first the left flex from...
      06-03-2025, 09:58 AM
    • Guybrush
      Dell U3419W horizontal lines and flickering
      by Guybrush
      After watching too many electronics repair videos (but not monitors) I came across a dell monitor with flickering horizontal lines. I haven't purchased it yet so don't have much info, but from the video and pic do you think there is a chance of repair or is just simple panel damage?
      Seller claims; "but due to sun damage has some grey lines going through it"
      https://i.imgur.com/VpTcZFn.mp4
      Chris...
      10-23-2023, 06:17 PM
    • Ihandyrepair
      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
      by Ihandyrepair
      Hi guys
      I just started fixing 4k TV few months ago. so I am still learning a lot
      I got this tv from friend complaint is ghosting or horizontal lines on image.
      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
      then it started to show the ghosting white image.
      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
      it has 3 thin small boards at the bottom of the...
      12-05-2022, 04:18 PM
