LG Plasma 50PK540 Lightning Victim LED Light Relay Clicks On Plug In Nothing Else
  • Michale32086
    replied
    Re: LG Plasma 50PK540 Lightning Victim LED Light Relay Clicks On Plug In Nothing Else
    I am assuming that checking the AC voltage, where the + or - probes are is not relevant??
    Comment #28 and #29 shows how I have the probes....
  • Michale32086
    replied
    Yep, that's how I did it..
    I hit the button to switch it from AC to DC and checked the outer pins.. Then I hit the button again to switch it to AC and checked the inner pins..
    I'll confirm it when I get to the shop, but I am pretty sure that's how I set it..
  • selldoor
    replied
    I am not sure you are using your meter correctly-
    Can you read the bit in the manaual where it is headed Measuring voltage.
    Whilst it is autoranging I understand it to say that it defaults to AC on turn on
    and you have to use a button to change to DC. Then if you want to go back to test AC you have to press the button again and so on- it does not auto switch from AC to DC
    Perhaps test again remembering HIGH voltages
  • Michale32086
    replied
    Each bridge gave the same result...
    On both, the DC voltage was all over the map from 120v to 170v and the AC voltage was dead.. No voltage at all...
  • selldoor
    replied
    Originally posted by Michale32086
    On the BRs, I checked both of them, both sets (outer at DC, inner at AC) and they gave me the same readings..
    Sorry do you mean each bridge gave the same result or you got the same result on AC pins as DC pins?
  • Michale32086
    replied
    On the VS/VA, I don't think I checked ALL the VA and VS pins.. and I did use both a GND pin on the connector and a screw connected to the ground tab and the frame..
    I'll check that when I get to the shop in about 2 hours...
    I also noticed that there are VS and VA pads right below one of the power connectors. I assume that is to facilitate checking of voltages.. I'll check those as well..
    I'll also check the DIODE...
  • selldoor
    replied
    As soon as I got to bed thought of something else but damned if I can remember what it was!! I should have said sooner I know virtually nothing about plasma sets - more at home with monitors & small tvs but I figure a power supply is a power supply so happy to look at basic stuff but we really need input from a plasmatition.
    Anyway when you did the AC test on the two Bridges and I said/thought "why" we have
    400v at the caps I am now wondering if you checked the DC on the outer pins on both
    as one might feed part of the board and the other might feed the part that sends power
    to the VS/VA sockets.
    That brings me back to this:
    Did you test all the pins on the top two connectors with the VA & VS pins on anddid you use the panel ground tabs for the black lead - try again with a screw in to connect it to the frame.
  • Michale32086
    replied
    I was thinking this is a pretty straightforward issue and not requiring a scope..
    Maybe I was wrong! {hope hope}
  • Michale32086
    replied
    I did not have the set plugged in. Whew!!!
    I thought that was a funny looking diode!! hehehehe
    I'll check the real diode in the morning...
  • vinceroger69
    replied
    Hopefully he didnt have the set plugged in when testing that on diode mode.
  • selldoor
    replied
    I checked the IC301 in diode mode.. All pins showed 0L. According to the PDF you sent (Thanx ) that means it's "open".. Dunno if that is good or not..
    http://www.ebay.ca/itm/LG-Power-Repa...item1e7a9db08a
    i wonder if this kit will sort it?
    kit contained 1 fuse (F302), 1 diode (D304) , two power resistors (R927, R929) and the IC301 voltage regulator IC.(found on another post)
    Ohhhh! that is not the diode - hope you havent killed it.
    Diode is at D304 IC is at IC301
  • vinceroger69
    replied
    I would wait and hopefully a plasma expert will come and chime in with ideas what to check next so far all your tests are ok im running out of ideas i suppose a lightening strike could of caused a power surge or also traveled down airel lead if connected so could be mainboard?.
  • Michale32086
    replied
    Originally posted by selldoor
    Yes - check all the pins on there black lead on that ground tab but put a screw in it to the frame first
    here are meter instructions and data for ic301 which is part of the pfc circuit so think it may be ok as well
    Off to bed soon so Goodnight
    Yea, I gotta go get the wife from work..
    I'll jump back on here first thing in the morning.. 0800hrs Florida time which should be around 1300hrs your time..
    Thanx to you and to Vince for all the help.. I am learning a ton!!
  • selldoor
    replied
  • Michale32086
    replied
    this is from another post of toms have you checked this?
    Do you think it will be possible to probe the AC_DET pin? You may need a piece of wire. Attach the wire to the red probe on your multimeter, and stick the wire on the AC_DET pin. Place the black probe in an exposed screw hole (e.g., for the wall mount.) Set your meter to the 20V DC range and move the probe to the volts/ohms jack. Then plug the TV in. You should measure either 3V or 5V. If it drops to zero during the clicking, you have a very common problem with LG plasmas which is easily fixed
    4.46v Holds steady..
    have you also checked you have 5v stby?
    M5V??
  • Michale32086
    replied
    It looks that way and the PFC must be working.
    Did you test all the pins on the top two connectors with the VA & VS did you use the
    panel ground tabs for the black lead - try again with a screw in.
    Next locate where the parts are in Vinces repair pack - you have tested the two white
    resistors are those the two resistors in the pack you also tested the fuse the fuse -
    so can you find and test the diode.
    Can you read the part number on the IC301
    EDITLast para edited
    I'll check the diode...
  • vinceroger69
    replied
  • selldoor
    replied
    He has Diode setting on his meter - just hasnt realised it - it is the same as
    ohms sign /]))))) beep? -triangleI- diode
  • vinceroger69
    replied
    Diodes can be checked with your normal multi meter with the set unplugged when toms online maybe he will have some ideas what too check ive only ever worked on one panasonic plasma that was a easy fix.
  • selldoor
    replied
    If you missed it please read my last post again- now almost in English
  • Rensiee
    Panasonic TH-50PX8EA Black screen, only relay clicks
    by Rensiee
    I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
    I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
    When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
    I have measured the voltage in the VSUS line, which...
    06-18-2024, 12:58 PM
    Samsung LN46b530p7f – relay clicks and backlight cycling, sound OK
    by momaka
    I got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
    Problem:
    Backlight cycles On and Off.
    Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark....
    01-17-2019, 11:23 PM
  • samtron786
    toshiba 46xv555d relay clicks
    by samtron786
    Hello
    The red and green LEDs both light up and you can hear the relay click. (no picture, no backlight, no sound)
    2-3 seconds later the relay will click again and only the red LED will stay on.
    I would be very grateful for any advice or a little help.
    circuit diagram?
    Thanks very much
    02-04-2023, 04:39 PM
  • jm1234
    9V relay temperature 40C
    by jm1234
    Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
    I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
    05-09-2024, 03:03 AM
  • edugimeno
    Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
    by edugimeno
    Hi everyone!
    I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
    I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
    This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
    To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
    I respected the polarity, positive to cathode of protecting diode
    So provided all...
    04-18-2024, 01:15 PM
