LG Plasma 50PK540 Lightning Victim LED Light Relay Clicks On Plug In Nothing Else
  • Michale32086
    • Nov 2011
    • 1453
    Re: LG Plasma 50PK540 Lightning Victim LED Light Relay Clicks On Plug In Nothing Else
    A check on the diode (D304) in diode-mode gives me a tone and a .00 on the reading..
    I assume that means a direct short??
    • Michale32086
      • Nov 2011
      • 1453
      Originally posted by selldoor
      EDIT
      Do you get any other voltages on the connector where you did the ACdetect test
      https://www.badcaps.net/forum/attach...0&d=1329432948
      Let me re-check that...
      • Michale32086
        • Nov 2011
        • 1453
        Originally posted by tw2005
        maybe try this,
        Interesting idea.. Lemme assemble the parts..
        I would assume it won't light the bulbs, as I get no reading on VS....
        But ya know what happens when ya make an assumption..
        Ya make an ass out of 'U' and 'umption'
        EDIT: I hope you know I was trying to be funny and wasn't calling you an ass..
        • Michale32086
          • Nov 2011
          • 1453
          AC-DETECT test shows 4.46v at plugin and holds steady...
          • Michale32086
            • Nov 2011
            • 1453
            Check the VA and VS points with the NEG clipped to the screw that was screwed into the base...
            VS showed .036v
            VA showed .001v
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #66
              I mean voltages on the other pins on that connector - also shown in TW2005 s diagram.
              (He is a plasmatition)
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #67
                VS showed .036v
                VA showed .001v
                Yes sad isnt it It is never going to light a bulb - we are going to need a schematic ( I half looked the other day then gave up) or a picture of the back of the board - will need to be the best picture you have posted. If you cant get it really clear so we can see the traces dont bother posting it.
                • Michale32086
                  • Nov 2011
                  • 1453
                  K Lemme get on that right now.. Do you need the whole board or a specific section??
                  I'll also check the other pins of the AC-DETECT connector..
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #69
                    That might be ok depending on what your meter does. Not sure you get a buzz
                    on diode mode - did you press twice?
                    A Buzz suggests something there and meter may report overscale as .00
                    If you can get it into ohms try that .test one way should be over scale and when you reverse the probes a reading more than 30 ohms
                    Whole board would be good - four quarters might do. Need to follow where the traces go from the
                    vs/va sockets - not that I am very good at following circuit traces.
                    • Michale32086
                      • Nov 2011
                      • 1453
                      All the voltages check out on the AC-DETECT.. 17v, 5v all present in their appropriate pins..
                      • Michale32086
                        • Nov 2011
                        • 1453
                        .4-.5 ohms both ways...
                        • Michale32086
                          • Nov 2011
                          • 1453
                          Here's the best pic I can do with my crappy phone...
                          I marked the Y and X connectors for easier reading..
                          • Michale32086
                            • Nov 2011
                            • 1453
                            maybe try this,
                            TW2005, I do have a Rigol Scope if you think it might help in diagnosing...
                            And I am itchin' to use it!!!
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              #74
                              Doesnt look good -but need to lift one leg to test again as it may be in parallel
                              to some high resistance.
                              Did you get your market cameras fitted - dont know when you have had time!
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8352
                                To help a little along here. SJ makes a power supply repair kit for 25$. Look at at the stuff they change out and check yours. http://www.shopjimmy.com/lg-eay60968...repair-kit.htm
                                Hopefully you not end up like
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  OK, I'll de-solder the piece and see what readings I get..
                                  Yea, we have to put in a few outdoor and wifi cams, so I got about half of them done. It's pretty straight foward work. I was US Army MI during Desert Storm and specialized in Surveillance/Counter-Surveillance..
                                  I can do it in my sleep. And often do!!
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    "I am definitely interested in THAT!"
                                    -Keannu Reeves, THE REPLACEMENTS
                                    I'll check that link.. Thanx
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      OK, I de-soldered the D304...
                                      When I use the meter in DIODE mode, I get 0L v one way and .20 v with a tone the other way...
                                      When I use the meter in OHM mode, I get 20K ohm one way and .568M ohm the other way...
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        #79
                                        We have done that using another kit???
                                        Michale cant make much of the traces but it does confirm there is nothing else
                                        on the VS VA sockets .
                                        Can you look on the back of the board - this section. Maybe the flash but
                                        one side of that transformer doesnt look good?
                                        • Michale32086
                                          • Nov 2011
                                          • 1453
                                          Looks like a bubble...
                                          • Rensiee
                                            Panasonic TH-50PX8EA Black screen, only relay clicks
                                            by Rensiee
                                            I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                                            I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                                            When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                                            I have measured the voltage in the VSUS line, which...
                                            06-18-2024, 12:58 PM
                                            Samsung LN46b530p7f – relay clicks and backlight cycling, sound OK
                                            by momaka
                                            I got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
                                            Problem:
                                            Backlight cycles On and Off.
                                            Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark....
                                            01-17-2019, 11:23 PM
                                          • samtron786
                                            toshiba 46xv555d relay clicks
                                            by samtron786
                                            Hello
                                            The red and green LEDs both light up and you can hear the relay click. (no picture, no backlight, no sound)
                                            2-3 seconds later the relay will click again and only the red LED will stay on.
                                            I would be very grateful for any advice or a little help.
                                            circuit diagram?
                                            Thanks very much
                                            02-04-2023, 04:39 PM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
