Samsung PN42D450A2D No Picture
  • Gadjet
    • Aug 2012
    • 248
    First there was a clicking sound that the TV was making coming from the power supply or the T-Con board. So I replaced the Power supply and it was still doing it. So I put the old one back in and replaced the T-Con board and it stopped so I thought that fixed it. It makes plays the chime like its coming on but the screen remains Black with no picture or backlight.
  • awyatt2
    • Feb 2012
    • 407
    • america
    Re: Samsung PN42D450A2D No Picture
    check the fuse on the xsus board. its a surface mount or pico type probally should be designated on the board by the prefix f. could be something out on the vs or va voltages as well. had a 52 plasma Sammy in here the other day wouldn't show a pic but sound was good, fuse on the xsus had opened. it used a small agc type fuse though in a holder.
    • Gadjet
      • Aug 2012
      • 248
      I replaced the xsus board and no change black screen no backlight any other suggestions?
      • capkid
        • Oct 2010
        • 1339
        First suggestion, as I've mentioned to others, is to stop replacing parts until a thorough diagnosis has been performed...unless you want to continue wasting money. These Samsungs are all over the forum, and they normally have Y-Main or X-main issues when the "no picture" fault occurs. Do you have a digital multimeter?
        LG Plasma Mal-Discharge Correction Service
        • Gadjet
          • Aug 2012
          • 248
          I just happened to have all the parts here from a tv with a broken screen, can't find the y main though. However I do have a multimeter.
          • Krenzy
            • Feb 2015
            • 45
            I'm a beginner, but I have a smiliar TV as you, with a similar issue. I do, however, recommend checking through my thread, as there are many great suggestions and tests listed within it. Hopefully we can both get our TV's back to normal.
            https://www.badcaps.net/forum/showthread.php?t=44057
            • capkid
              • Oct 2010
              • 1339
              I'd pull the X-main and Y-main to test the components on the heatsinks for shorts. This thread might be useful:
              https://www.badcaps.net/forum/showth...t=Ns-50P650A11. There are some instructions in post #10 if you need them.
                09-07-2024, 05:50 AM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • JJAAMM
                by JJAAMM
                Problem
                07-06-2023, 06:01 AM
              • Dodgethis
                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                by Dodgethis
                Hello all,
                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                09-11-2024, 07:39 AM
              • YellowJacket
                Samsung QE55Q60RAT - no picture
                by YellowJacket
                Hi friends,
                a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
                07-30-2024, 01:31 PM
