Sony KDL-46Z4100 distorted image with green vertical lines
  • masessum
    • May 2012
    • 8
    Re: Sony KDL-46Z4100 distorted image with green vertical lines
    Hello folks...don't post here much, but have found some good tips over time so I reckon I'll contribute...I looked at the image from the Sony BT2 board, usually the regulators on the board short out, & no picture appears. If you have a voltmeter, check the voltages just to the left of the "BT2" stamped on the board...the top should be 3.3v & the bottom, (Cayenne-T) 1.0v. The other two about 1.9v I believe. Don't run the board long without heat shield in place or else....
    • cope360
      • Jan 2015
      • 5
      Conclusion (in case anyone is still following this thread):
      • I was not able to find any T-CON boards of this model for sale.
      • I was not able to find anyone online who was interested in repairing this model of board.
      • My soldering skills are not good enough to try it myself
      • I took it to a local shop and they offered to "rebuild" the T-CON for $195 and offered a 60 day warranty.
      Since I can get a new TV with equivalent specs for about $500 this will be the end of the line for this Sony. Now just to decide what to buy to replace it...
      • Flyfishman59
        • Feb 2017
        I have a issue my standby light is not on but I can turn on the T V and the fonts bleed down and snow on the displayKDL-46Z4100. Re-seated connector. I just don't know why I have no standby light
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4396
          • Italy - Milan
          Flyfish it don't seem the same issue as the O.P. so please open a new thread..
          cope360 have you trashed the tv? I don't think 195$ is so high price instead of 500$, i really don't understand your point of view... :-(
          i have repaired an expensive tcon on some Sharp panels, the faulty part was a mosfet, here there are 8 in a row, my first watch is to them..
          • 265chemic
            Samsung LA46A950 aka. LN46A950 - intermittent vertical green lines / distortions
            by 265chemic
            Hi All,
            I have a Samsung LA46A950 that intermittently was displaying issues with evenly spaced vertical green lines only on dark / black areas - this has progressed to more often and blue lines sometimes, as well as a little image distortion.
            My initial suspicion was the T-CON board, which I took out and cleaned but the issue persists. A heat gun on all of the control boards makes no noticeable change. Ive also reseated the T-CON to panel ribbons (4 of them) and moving them while the panel is on doesn't seem to change the issue.
            Below are some photos...
            03-23-2022, 04:53 PM
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            Sadly it has vertical lines at the left and one line in the middle-right.
            I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
            I have factory resetted the TV as well but also with no luck.
            I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
          • visionbluedemon
            Help. Sony kd-65x85dj vertical lines
            by visionbluedemon
            First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
            Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
            tried blocking LC lines too, but same results
            is it lcd panel issue or tcon board issue?...
            07-25-2025, 04:56 AM
          • arctor
            samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
            by arctor
            hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
            04-26-2025, 05:22 AM
          • gpo23
            Sony KDL-40V3000 - Vertical lines
            by gpo23
            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
            With the new t-con the color are good but there are vertical lines on all the screen :
            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
            Is there a way to fix the vertical lines on the new t-con ?
            Thank you for your help
            gpo23...
            10-04-2023, 09:11 AM
