LG 47LB6300 - Bad Mainboard or TCON?
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Another possible learning experience. This set has a damaged screen, but backlight appears to work, and set powers on and off and responds to remote.
    The problem is there is no sound from the set, and I don't see any screen changes on the LCD for picture (just white backlight). Also, the optical out and network cable jack show no light on the mainboard.
    Attached a picture of the mainboard. Didn't dig down to the TCON yet. There is a really small reset button of some sort on the main. When pushed, the backlights turn off, then back on when released.
    Thanks for any help!
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Re: LG 47LB6300 - Bad Mainboard or TCON?
    Any ideas on this one? Could the power board be at fault?
    • selldoor
      Slow Learner
      • 7870
      Perhaps set it all up - with a signal source dvd/pc ? scroll through the "sources "using the remote see if anything occurs . Try for sound with headphones press the "mute" button
      and try volume up on the remote. Next check the voltages on the connector from the power supply to the main - there may be clues near the socket as to what voltages there should be. - post a picture of the power supply.
      • stylishconsultant
        un60j620dafxza - Samsung No Display Problem
        by stylishconsultant
        Hi All,
        Need help.
        I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
        So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
        problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
        might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
        09-04-2024, 03:26 AM
      • Fly_Among_Stars
        VIZIO E70-E3 Half picture with half TCON
        by Fly_Among_Stars
        I have a VIZIO E70-E3.
        Symptoms: Black screen, no picture, but LED backlights are working.
        I probed the power board and voltages are as listed on the board.
        Main board appears fine, too.
        I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
        There are two separate ribbon cables feeding the LCD.
        If both are connected, the screen is black.
        If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
        04-24-2023, 08:20 PM
      • iglitare
        by iglitare
        09-04-2025, 07:13 AM
      • TerraPhantm
        Sony A8H to A80J mainboard upgrade possible?
        by TerraPhantm
        I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
        So I decided I'd experiment a little bit.
        I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
        When...
        08-15-2023, 08:10 AM
      • wattage
        AOC AG493UCX 49-inch monitor - Firmware request
        by wattage
        Hello Badcaps Community,
        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
        07-13-2025, 04:41 PM
