Maxent MX-5020HPM plasma - main board vendor
  • Stevie B
    • Oct 2014
    • 32
    Where can I buy a QPWB11578Y1G--- board?
    Shop Jimmy is out of stock.
    Also, I would like to know if different versions of the board will be OK.
    At River Valley Electronics, they are selling a QPWB11578Y1G-1-.
    My board has the additional part number as 50P6I11-06675 but theirs is listed as 50P6I11-05713.
    Will this be ok?
    From a separate thread, it was suggested that I replace this main board (judging from the symptoms).
  • Shinju
    • Mar 2014
    • 1239
    Re: Maxent MX-5020HPM plasma - main board vendor
    Does Shopjimmy list any other boards as suitable substitution and is that Rivery Valley board on that list?
    In my most humble opinion, with plasma displays it is best to replace the parts with matching part numbers or parts that are known to be compatible with your panel.
    If you don't know I would research before spending money on a part that might not work or may cause compat issues.
    • Stevie B
      • Oct 2014
      • 32
      I guess I need to ask how to research this kinds of detail.
      On the River Valley page, it lists the same part number as DPWB11578MPP. This number appears on a sticker on my board.
      The differences are in the suffix; QPWB11578Y1G--- Vs. QPWB11578Y1G-1. This number is printed onto the board.
      Also, on another sticker, my board has 50P6I11-06675 and they have a reference to 50P6I11-05713.
      I have no idea what these differences mean.
      • Stevie B
        • Oct 2014
        • 32
        After calling 2 suppliers (they both said the same thing), it seems that the only thing to go by is the "Part Number", which is on a sticker.
        The "Board Numbers" don't matter.
        Apparently, they can use the same "board" (either bare or with some components) and configure it into a specific "Part Number".
        There are 3 stickers on my board - none of them give any indication for which is the "Part Number". But the suppliers seem to know.
        So I went a head and bought the board from River Valley.
        The best part is - I can return it if it's not the problem! That was a surprise.
        • Stevie B
          • Oct 2014
          • 32
          River Valley Electronics - I ordered the part on Wednesday and received it on Friday - free shipping, no sales tax.
          I swapped out the board and voila! my 50" is back!
          Got it back up on the wall too.
          What should I do with the old board?
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
            by JDC
            ONN 100012588
            Issue: No Power, Then Rebooting After Main Board Change
            Short answer: replace main board and power board
            Technical answer: replace main board and Q306 & Q307 on power board.
            Long answer:
            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
