Vizio VW37L screen flickering
  • whiz62
    whiz62
    • Dec 2013
    • 242
    • usa
    Just thought I would post this on what I found. Two caps on inverter board slightly bulged and leaking. They were 680uf 35v. They read only 118uf after removal. All I could find today was 680uf 50v in town. Slightly bigger diameter but still had plenty of room with shield installed. oops. had wrong model number on title.. glad I caught it.
    Re: Vizio VW37L screen flickering
    Using low ESR/IMPEDANCE type?
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • Ado02
      Lenovo Thinkpad X1 Gen 10 - Flickering Screen
      by Ado02
      We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
      The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
      12-16-2024, 02:33 PM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • survivalbloke
      HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
      by survivalbloke
      SN: 8CG0213H8W
      ProdID 3C311UA
      This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
      05-08-2025, 12:21 PM
