EMERSON LC320EM1F Hit power button, red led blinks 5 times then ........ Nothing anyo
  • Twist1up
    • Jan 2015
    EMERSON LC320EM1F Hit power button, red led blinks 5 times then ........ Nothing anyone got any ideas??? plz
  • Twist1up
    • Jan 2015
    Re: EMERSON LC320EM1F Hit power button, red led blinks 5 times then ........ Nothing
    anyone can you help me with this.... when its plugged in the power light will go on but when try to power it on it flashes 5 times and goes out. so i was thinking just buy a new power board off Ebay. think that will work?
    • nomoresonys
      • 12206
      • U.S.
      need a better description, what do you want to do, troubleshoot or guess at it?, if you want to troubleshoot, read the first post in this category, how tvs work, then some good clear pictures of all the boards and one of how they are all connected, be careful working with power supply, HIGH VOLTAGE, on primary side.
      • Twist1up
        • Jan 2015
        basically i don't have the tools to test it so there's 2 boards the power / logic & inverter i just want to replace the whole thing with working one but witch board is it causing the problem
          Without tools, then buy both boards, install them and see if the TV works, then put one old bad back in one at a time, the bad part about doing it like this is that if the bad board can take out the new board.
          • nomoresonys
            • 12206
            • U.S.
            hell it could be anything starting from your power cord right up to the panel.
            • Biruslapio
              Panasonic P58V11B 8 and 12 blinks error "fix"
              by Biruslapio
              Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
              Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
              04-13-2021, 07:13 AM
            • Nairolf
              Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
              by Nairolf
              I have a Samsung DM32D display.
              When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
              Here’s what I have tried so far:
              1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
              2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
              3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
              From these tests, I suspect the problem might be on the mainboard. Could anyone...
              08-24-2025, 03:47 AM
            • Andre Gilbert
              by Andre Gilbert
              11-20-2024, 08:52 PM
            • Taurus12
              Optiplex 3050 micro 2 blinks followed by 3 blinks issue
              by Taurus12
              Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
              I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
              i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
              Any recommendation on what I have to do next? Thanks in advance
              06-10-2025, 05:05 PM
            • jchon
              Sony A1e 5-blinks help
              by jchon
              Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
              I found the service manual, which was critical to know where to probe.
              https://www.manualslib.com/manual/20...1e-Series.html
              With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
              Unfortunately the 5-blinks...
              06-28-2023, 11:52 AM
