LG 50PV400 black vertical lines and twin sections
  • ponchorage
    • 16
    I just picked up this set for my first attempt at TV repair. The guy I bought it from said he thought one of the x boards needed to be replaced. It's got a several inch section of black vertical lines with a couple of gray lines interspersed that start at the bottom but don't go all the way up and they flicker. To the right of that, and this is strange, there are dual vertical sections. It's like a small slice of the screen gets repeated. The pictures I've attached will explain it better than I have.
    From my research it seems it could be a bad tape carrier package but I'm really hoping it is just an x board gone bad. Any tips on figuring out what is really going on here?
    Re: LG 50PV400 black vertical lines and twin sections
    Find the control board, it's a little green board usually just below the power board, and upload a picture of it. There is a test that can be done on it.
    • ponchorage
      • 16
      Here is the photo of the control board. Looks like somebody had already removed the tape over one of the ribbon cables. Thanks for your help!
        Ok, above "LGE PDP 101019" there are two holes near "R51" and "R52". Place a wire jumper across these, and disconnect the largest right hand ribbon cable. When you plug in the TV, do you get cycling test patterns? Is all the screen working or is that area still dead?
        • ponchorage
          • 16
          Please forgive my ignorance as I've never done anything like this before. Would it be ok to just use a short length of copper electrical wire for this? I don't need to solder anything since this is temporary, right?
            Yes, just needs to be a little wire jumper, not permanent, you will remove it after test is done.
            • ponchorage
              • 16
              I got the cycling test patterns. That area of the screen was still dead.
              • ponchorage
                • 16
                Only if it was jumpered correctly would it do the cycling test, right? So does this mean the panel is bad or do I need to check something else?
                • ponchorage
                  • 16
                  I tried it without the jumper and didn't get the cycling test so I assume that worked. Could there still be a problem with another component?
                    Personally I think it's the panel, but maybe you can replace the XL/XC/XR-buffer boards, they are usually cheap. Maybe worth the risk?
                    • ponchorage
                      • 16
                      Yeah, it's only like $30 for those on eBay so I'll probably give it a shot if you think it's still a possibility it could be those boards. Thanks again for all your help tom66!
                        Just a note, only replace the board corresponding to the right section. Each board is immediately below the area it controls.
                        • ponchorage
                          • 16
                          OK, so looking at the TV from the front (viewing the screen), it is the right side that has the problem. So, I should replace the board on the left side, looking at it from the back, correct?
                            Follow the fault down. It will be controlled by one of the boards. Sometimes there are one, two or three boards. One or two is easy. Three is harder.
                            • ponchorage
                              • 16
                              So, I replaced the board and I still have the same issue. Is it possible that the control board is bad or is it the panel for sure now?
                              • Shinju
                                • Mar 2014
                                • 1239
                                tagging myself in this thread, curious as to why your test patterns are not showing up and your outcome.
                                  You can try the control board but I would be surprised myself. I don't see it causing the fault. Most likely it's the panel, unfortunately.
                                  • ponchorage
                                    • 16
                                    The test patterns come up just fine when I use the jumper. I just happen to also still see the black vertical lines. Are you thinking I shouldn't see those while using the jumper?
                                    My outcome so far is the same as when I started - seeing the black vertical lines.
                                    I'm tempted to order the control board if there is any possibility that it is the cause of the problem.
                                    Is there not a more systematic way to eliminate components as being the problem with these LG sets? I've seen that type of breakdown in the Panasonic service manuals where they walk you through how to detect which component is causing the problem.
                                    • Shinju
                                      • Mar 2014
                                      • 1239
                                      Sorry, I miss read. From what I understand these test patterns by pass all processing. I am not sure how they work as my 60PV450 has both a blown Y and X board but they were still able to produce a test patten (the image quality was shite) but I was able to see them full screen.
                                      After my probe slip on testing voltages on the Ymain, now I cannot get them to come up at all and when I turn on the panel no test pattern jumper all I get is a quick top half of the screen flash and shut down, MB and audio still active.
                                      Just curious since you have the PV line too to see what your findings and outcome will be.
                                      • ponchorage
                                        • 16
                                        Found a control board for $10 on eBay. Worth a try. Feel like I'm shooting in the dark.
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • visionbluedemon
                                          Help. Sony kd-65x85dj vertical lines
                                          by visionbluedemon
                                          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                          tried blocking LC lines too, but same results
                                          is it lcd panel issue or tcon board issue?...
                                          07-25-2025, 04:56 AM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • Firentiosi
                                          1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                          by Firentiosi
                                          Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                          The issues are as follows: the...
                                          11-27-2024, 12:33 AM
