S42AX-XB01TV help
  • wschaffee2
    • Jan 2015
    S42AX-XB01TV help
    I'm replacing the main board on this model tv, and have a black wire that fell out - obviously anchored with one of the mounting screws on one end, but have no idea where it belongs. Suggestions?
    The exterior tag says Dell W4200HD. The interior tag is Samsung S42AX-XB01.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: S42AX-XB01TV help
    It's probably just a ground wire and can be mounted to the closest screw available. If you mean it fell out of the connector, do you know which connector it came out of? Does it still have the crimped end on it or did the wire fall out of the fitting as well?
    • technicalspecialist
      Vintage fan repair, copper wire question
      by technicalspecialist
      I currently have a customer's vintage fan on the work bench to repair.
      It uses an induction motor with 4 poles. One of the poles is open.
      I couldn't find the break so i cut off the original wire.
      I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
      I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
      The enamelled copper...
      03-16-2023, 12:54 PM
    • mar1in
      Fix broken tinsel wire on Speaker
      by mar1in
      I've saved a pair of Philips AH 495 speakers from landfill and diagnosed the woofers are not working due to a loose or broken tinsel wire just on the joint of the cone (left wire on the picture)
      What's the best and easiest way to fix this without damaging the cone ?
      Can this be simple soldered on?...
      10-12-2023, 05:07 PM
      How do they work “BEHA Unitest Wire Sorter Identifier” feedback wanted
      I am thinking about buying one used if the seller will take my offer
      I just curious on how they work can anyone explain how they work
      I am trying to fix a shear that has a bad selector switch and the manual for this machine is terrible at best so I need to use a wire sorter to figure out where each wire goes on this machine
      This is the reason for buying on the seller made me a counter offer that I accepted for this tool
      10-07-2023, 02:21 PM
    • TacoLoco
      Benq G2420HD wire identification/assignment & LED conversion
      by TacoLoco
      Long story short... ccfl's failed, bought this "ca-155" led replacement but can't identify pin/wire assignment on both power supply board and logic board since neither have anything printed over the pcb, no ENA, DIM, VCC, GND, 5v, BL-ADJ or anything like that, nothing!!!
      Hello everyone and let me start with two warnings to help you understand the text wall ahead :p
      first, my english is absolutely bad, mediocre at best so i apologize in advance for making your eyes bleed, you may think "then what are you doing here and not searching the help you need in some...
      05-05-2019, 03:24 AM
    • sigmeyer
      Repairing a heater wire in a toaster.
      by sigmeyer
      First of all i just wanna say i love posting on this website and i get alot of useful feedback doing so , i just wish i could do it more often...
      Okay , so i am currently doing nothing because of the corona outbreak thing and i was trying to repair a cheap toaster that i have...And unfortunately it is just as i thought , the heater is broken. And i was wondering what can i do about this? So here is what i tried so far
      I have dissasembled an old chinese soldering iron and i took the heater wire from it to try reconnect the broken heater wire... and it worked untill the wire...
      05-25-2020, 07:21 AM
