Samsung Plasma PN50C550G1F : no image, but sound is ok
    Re: Samsung Plasma PN50C550G1F : no image, but sound is ok
    There's one thick cable going between main A/V board and power board, disconnect that and jumper anything required on there. Disconnect the connector between the control board (also called logic board, small green board usually below power board) and power board too.
    All right, just to recap...
    DISCONECT ALL 3 CABLES
    I disconnect the CN804 that is connected to the Y-Sustain board.
    I disconnect the CN802 that is connected to the logic board.
    I disconnect the CN801 that is connected to the main A/V board.
    JUMPERS:
    Install the jumper on the CN801 cable?
    i'm asking, because in your post, you're talking about the cable connected to the main A/V board (CN801) and that cable is wider/larger than the CN802, but tinner... Also, that connector only has PS-0N that seems relevant.
    The CN802 on the other hand has both PS-ON and VS-ON, and in previous posts, MagicSmoke told me to drive them to activate the PowerSupply and the Vs DC line ...
    Jay
      Ok I have try the following:
      Disconnect the CN804 that is connected to the Y-Sustain board.
      Disconnect the CN802 that is connected to the logic board.
      Leave the CN801 connected to the main A/V board.
      Add 1K resistors on CN802 connector:
      - pull down on PS-ON
      - pull up on VS-ON
      The DC voltages on test point of power supply are steady at:
      212 VDC for Vs
      55 VDC for Va
      Which is what the label says
      So I guess the the power supply is fine.
      What would be the next step?
      troobleshoot/check the Y-Sustain, Y-Buffer, Logic ???
        At this point, connect the control board back to the power board, and check if the voltages appear, then go away.
          if I reconnect the logic board, I'm back to this setup:
          Leave the CN802 connected to the logic board.
          Then the DC voltages on test point of power supply starts at:
          212 VDC for Vs
          55 VDC for Va
          But immediately starts to ramp down to 0 VDC
          The logic board LED do its pattern 5 seconds on, 2 seconds OFF
            Ok, everything connected as it is now, check VSCAN voltage on Y-main board.
              Is Y-Main board is the same as Y sustain board?
              Is VSCAN the same as VS? or is is some sort of "flat" testpoint on the Y-sustain board written VSC beside it ?
              Right now, the y-sustain board isn't connected to the power supply (cable CN804 is disconnected). Do I need to connect the CN804 cable to power up the Y sustain board?
                Y-main = Y-sustain
                VSCAN and VS are different. VSCAN and VSC are the same.
                  Y-main = Y-sustain
                  Ok,
                  On the testpoint VSC, the voltage is 0.
                  But as I said, like it is setup right now, the Y-sustain is not given power by the power supplu (CN804 is unplugged).
                  So I guess, you want me to connect the CN805 cable and see if it receives VSCAN voltage at all?
                  If I do, then all cables will be connect, because Y-sustain board is the only one that is unconnected right now.
                  Jay
                    Yes please do that, and check VS/VA too. The cable between power board and main board should be disconnected and the jumper resistors should be in place.
                      When I connect the CN804) (all boards are connected), the VSCAN (VSC) behave like the others voltage lines : it starts at its nominal value (-190VDC) and then ramp down to 0VDC in about 20 seconds.
                        Ok, can you check Ve on the X-main?
                          Ok I try this later tonight (leaving for family diner) and report the results...
                          So it will be :
                          y-sustain connected (CN804)
                          A/V board connected (CN801)
                          main board not connected (CN802), but using jumpers to force Vs drivers.
                          An measure the Vs, Va, Vscan lines
                            will also check the Ve on the X-main board too using the same setup (using jumper to bypass the logic board).
                            Thanks for your help...
                              A/V board should *NOT* be connected, use resistors in place of it to turn on power board.
                              Connect logic / control board (small green board below power board) for these tests.
                              The A/V board and main board are two names for the same thing. The logic / control is separate from the main board.
                                This is not where I use the 2 resistors on my previous trial...
                                On the connector CN801 (that connect the PSU to the A/V board, there's no VS-ON pin, only the PS-ON pin). So you want me to install a pull down on the PS-ON of the CN801 connector (by using a 1K resistor between it and a gnd pin as shown on the picture)?
                                The logic board might still detect a problem and still generate the protect mode (led blink 5s on, 2 s off). If this is the case, the Vs will not be generated and so is all the others voltages...
                                The only way I was able to generate a steady Vs out (and Va and others), was when the logic board was disconnected and when I was using pullup/pulldn on the VS-ON and PS-ON ...
                                I just want to make sure I understand the testcase you're talking about ...
                                  image of where I would install the pull down to bypass the A/V board since it would be disconnected (force the power supply to on).
                                    just a side note...
                                    When all boards are connected, the Vs, Va, Vscan starts at their nominal values, but decrease to 0 when the logic board puts the power supply in protect mode.
                                    The Ve on the Xboard, remains steady at a 0 flat all the times. So that one doesn't seem to behave like the others...
                                    I have tried to force the power supply to ON by adding a pull down on the pin PS-ON of the cable CN801 (A/V board) (1k resistor between the PS-ON pin and gnd pin as show in picture attached in previous post), but it doesn't wake up the power supply. Not sure If I need to add a pull up/dn on other pins such as Standby or if the wake up is not a fixed pulldn, but rather a temporary "pulse" to emulate a button press. If you an tell me how to turn on the power supply when the main A/V board isn't connected ... It would be appreciated.
                                    Jay
                                      I am aware the control board will shut down but it needs to be done this way because some Y-main/X-main boards will not turn on the voltages until the control board sends the right commands.
                                      You might need a lower resistor than 1k.
                                      You may also need to disconnect the LVDS cable (between the main board & control board) and jumper pins 3 & 4 on the control board diag connector to activate the test patterns mode, which will force it to generate control signals even if the main board does not send the right commands.
                                        So I only have to ground (or pull down with a lower resistor) the PS-ON pin of that connector. I leave all other pins open right?
                                        Just to make sure I'm not mixing names again:
                                        - main board = A/V board (the one with the hdmi and other connector)
                                        - control board = logic board
                                        The diag connector is the CN2011 connector (the only one that isn't connected by default) on the logic board right?.
                                        Do you want me to do all of these in 1 trial:
                                        - gnd PS-ON pin, disconnect LVDS cable and add jumper 3-4
                                        Or you want incremental trials
                                        1 - gnd PS-ON pin
                                        2 - gnd PS-ON pin AND disconnect LVDS cable
                                        3- gnd PS-ON pin AND disconnect LVDS cable AND add jumper (3-4)
                                        I'm leaving for beakfast, so I'll try this when I come back.
                                        Thanks again for your time (and patience)
                                          Correct.
                                          Yes, and the control board is the smallest one, usually below the power supply
                                          It's a little four pin connector, 0.1" spacing, square in shape and should not be connected. Vetical. Pins marked 1, 2, 3, 4. There may be another connector but don't use that as it's probably the programming header.
                                          1 - gnd PS-ON pin
                                          Please try only (3) for now.
