Samsung UE48J6200K - No image but sound
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Hi:
    This TV turns on and it can show picture for some seconds (sometimes minutes) then picture freezes and fades away. What I've seen so far is that the T-Con (BN41-021101A) starts with three leds on, but as soon as led3 turns off, just 12V and 3.3V (the bold ones) remains in the PCB but all others disappear.
    If I remove the 2 bellow ribbons, LED2 never turns on. I was trying to look for the "T-CON ready" pin to shorten with 3.3V and then test just the TCON without the panel (haven't found it yet)
    Not sure how to proceed here..............how can I know whether it's a TCON issue or a faulty panel?
    Any ideas, more than welcome.
    Regards,
    Francesc.
  • EazyBone
    • Jun 2023
    • 1364
    • United states
    Pictures of all board would be helpful. Generally freezing picture and distortion are because of main board failure. This is a TCON/main together I assume?
    • Francesc V.
      Tempus fugit
      • Nov 2022
      • 231
      • Catalonia
      This is the whole mosaic. I am assuming TCON is failing because it looses voltages after some seconds after the TV is switch on. the "SMART TV" logo appears, and later on clear picture or clear menu...........then image fades (it can last some seconds or from time to time some minutes).
      • Francesc V.
        Tempus fugit
        • Nov 2022
        • 231
        • Catalonia
        HI:
        Some follow up with my investigations trying to unprotect TCON and isolate the problem.
        This PCB doesn't have any TCON-RDY or similar pin as shown in other videos to unprotected it..........so I've seen a similar Samsung TCON that was unblocked with the following method and I've just tried it.
        It seems (DO NOT TAKE it as an statement) that shortening PIN 28 (left ribbon from left to right) and PIN 28 (right ribbon from right to left) that TCON also gets unprotected. TCON turns on without panel ribbons connected (although picture shows them connected).
        With panel ribbons disconnected and TCON unblocked, only main LED 12V and 3.3V led are lighting (missing Vdd light).........a new TCON is on its way.
        I've ordered same TCON model but it says 55inches..............is it as easy as moving the marked resistor from 55' to 48' before installing and give it a try?
        Regards,
        Francesc.
        • lotas
          • Jan 2016
          • 4966
          • Russia
          You will also need to transfer the spi flash W25Q40 from its original one to a new one (all the settings of your panel are stored in it).
          • Diah
            • Feb 2013
            • 6647
            LED 3 power supply from, AVDD, Voff.. mean there are issue to cut off.
            • Francesc V.
              Tempus fugit
              • Nov 2022
              • 231
              • Catalonia
              Thanks lotas. I will have a look. I am marking the one I might think you are refering to.........could you please confirm it?
              • Francesc V.
                Tempus fugit
                • Nov 2022
                • 231
                • Catalonia
                Yes.......it seems so. But I am just an idiot trying to find the issue :-)
                Also, the PIN28 thingie doesn't seem to work for this TCON model..........(led2 doesn't turn on with panel ribbons disconnected; not even for seconds-minutes as the original fault).
                • Diah
                  • Feb 2013
                  • 6647
                  LED 2, are feed back if the panel turn on so the secondary power supply of the processor and RAM of the t-con will be present
                  • lotas
                    • Jan 2016
                    • 4966
                    • Russia
                    Yes, he is the one.
                    • lotas
                      • Jan 2016
                      • 4966
                      • Russia
                      Take a high-quality photo of this area.
                      • Francesc V.
                        Tempus fugit
                        • Nov 2022
                        • 231
                        • Catalonia
                        Ok.......so that explains that this part doesn't turn on if panel ribbons are not present or card is tested isolated by injecting 12V in the input.
                        Any idea how to force/unblock that TCON model in order to simulate that feedback?
                        • lotas
                          • Jan 2016
                          • 4966
                          • Russia
                          I asked you to take a high-quality photo.
                          • Diah
                            • Feb 2013
                            • 6647
                            disconnect the MB from PSU.... also disconnect the LVDS from T-CON side..
                            turn on and find 12V VCC on the PSU to feed the T-CON Fuse direct with it.
                            • Francesc V.
                              Tempus fugit
                              • Nov 2022
                              • 231
                              • Catalonia
                              Yes. Hopefully this one is better. I've found a TCON_READY pin that has 3.3V when 12V injected in the fuse. I guess I need to find another point in the PCB to shorten it. Ground this point doesn't make any difference (no Vdd,,,,,,)
                              ​Yes.........right now it's on the table isolated.
                              • lotas
                                • Jan 2016
                                • 4966
                                • Russia
                                Connect RM15 (put a jumper) remove the black wire..
                                • Diah
                                  • Feb 2013
                                  • 6647
                                  MY Post and my way to have it in Tv with panel connected.... alone on table what you will reach ?? nothings
                                  • Francesc V.
                                    Tempus fugit
                                    • Nov 2022
                                    • 231
                                    • Catalonia
                                    This testing I have it pending. I need my wife not to be at home as the test requires "some space". :-)
                                    I'll let you know the outcome during the weekend.
                                    Thanks Diah for this suggestion.
                                    • lotas
                                      • Jan 2016
                                      • 4966
                                      • Russia
                                      So place the jumper as described above and supply 12 V to the t-con, this is without a panel, the panel is not needed here and check the voltage at the output.
                                      • Diah
                                        • Feb 2013
                                        • 6647
                                        LOL.... lotas T-CON never being Voltage or currents,,, so what are all these muscle training you are showing here... LOL.... T-CON must an Panel connected... and must too the 12V VCC from it own PSU to match Freq. .... this is MUST if one want to handle T-CON in case he didn't have in hand Oscilloscope ... end of muscle training show.
                                        • wolf1976
                                          samsung ue40d6100 has no backlight no sound and image
                                          by wolf1976
                                          hi to all
                                          on the above model of samsung i have the faults i have told already on the title
                                          iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                                          any idea from someone what can i measure so i can find the problem ?
                                          the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                                          11-17-2024, 01:02 PM
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                          09-07-2024, 05:50 AM
                                        • andrhouseolly
                                          Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                                          by andrhouseolly
                                          Hi.
                                          I kindly ask you to help me solve the problem.
                                          Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                                          The board turns on, there is no image.
                                          Read more. When the power supply is connected, the front panel indicators light up briefly.
                                          When you press the power button, the button indicator lights up. The board works
                                          there is no image, there is no matrix initialization, there is no image on HDMI.
                                          When turned on, the fans do not spin, but when they warm up they start spinning.
                                          When you turn off the button, the fans spin up to full speed for a short...
                                          05-11-2024, 03:14 PM
                                        • Egidio85
                                          Samsung UE55F8000SZ Turns on and off immediately
                                          by Egidio85
                                          good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                          This defect happens continuously, hearing the classic click of the relay every time.
                                          Power supply board BN44-00636B
                                          disconnecting the mains and lamps from the power board always causes the same problem.
                                          Is it normal that without anything connected this power supply turns on and off cyclically?
                                          any suggestions on what to check?
                                          thanks in advance
                                          03-11-2025, 12:45 PM
