Fault on panasonic veira th-58pz800b
  • 1967tux
    • 29
    Re: Fault on panasonic veira th-58pz800b
    i tried new c buffers with the new board the old board is totally gone so it is displaying to 58" but i hear what you are saying i think the way forward is to try and source the correct d board. is there any way i can test the panel the part that is not working seems to have a slight glow so im fairly sure it is ok.
    • 1967tux
      • 29
      thanks for the suggestion tw but a bit beyond my skill set! im only a sparky not to confident soldering small electronic components lol.
      • tw2005
        • Oct 2011
        • 6458
        I'd be confident it's ok and it needs the correct d board . If you look at the block diagram, ic9300 and 9400 provide the data for the c buffers. IC9303 is the data those 2 need to address the panel correctly.
        bothe ic9303 and 9001 are a different part number meaning different data is programmed into those (panel size specific)
        • Shinju
          • Mar 2014
          • 1239
          To me looking at your side shot photos your panel is not even priming on the voided areas, but again that could be the contrast in the photo.
          Do you see any screen glow/sparkles or anything in the "dead zone"? Best to view this in the dark to view the screen prime.
          • 1967tux
            • 29
            ideal new d board it is then will keep you posted on progress thanks for your help and advice much appreciated
            • 1967tux
              • 29
              #26
              yes the screen defiantly primes its hard to pick up with the camera.
              • tw2005
                • Oct 2011
                • 6458
                unfortunately you've introduced an unknown variable, without trying the correct board I don't know how else to prove panel or not. i would not experiment though.
                • 1967tux
                  • 29
                  #28
                  hi TW2005 i have still not got round to sorting this one yet, i have however been practising my soldering skills and am now ready to attempt a repair. the only trouble is that the original ic9303 chip is the one that is blown. excuse my ignorance but the markings on the chip are as follows:
                  spansion
                  S29AL016D70TF102
                  823BBS88 H
                  04 SPANSION
                  on the other board ( from the 42" ) the chip looks the same and markings are as follows:
                  spansion
                  S29AL016D70TF102
                  825BBk51 H
                  04 SPANSION
                  are these chips the same? which is the part number ? do these chips hold size specific data on them?
                  i was thinking if the chips were the same and did not hold data on them so to speak, i could take the one off the 42" board and use it to replace the damaged one on the original board. sorry if that sounds stupid but im not that experienced in this sort of thing!
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    #29
                    TELEFIX
                    • tw2005
                      • Oct 2011
                      • 6458
                      spansion
                      S29AL016D70TF102
                      823BBS88 H
                      04 SPANSION
                      spansion
                      S29AL016D70TF102
                      825BBk51 H
                      04 SPANSION
                      If the original IC9303 is shot there's no point swapping, may be able to get an original new one programmed from panasonic, GTV Watford would know.(Ebay)
                      Could be a waste of time and money. how do you know the original is blown?
                      These do hold data and are model specific.
                      • 1967tux
                        • 29
                        #31
                        i know it blown as there is a hole in it can see the inside the chip
                        • tw2005
                          • Oct 2011
                          • 6458
                          crikey, sounds like a lightning strike?
                          • Terryfictv
                            • Mar 2011
                            • 124
                            Andrews Electronics says TNPA4439APS
                            shop jimmy list = http://www.shopjimmy.com/catalogsear...lt/?q=TNPA4439
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • Alicat
                              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                              by Alicat
                              Stopped by this site trying to fix my parents Panasonic Plasma TV.
                              Model number is TH-50PZ85U
                              Power comes on and the red power light stays on solid.
                              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                              I also hear a few clicks.
                              I also think my parents said there was a thunderstorm and the TV failed after that.
                              Section 6 in the service manual talks about power and no screen,...
                              10-30-2024, 10:09 AM
                            • reformatt
                              by reformatt
                              07-31-2025, 08:37 PM
                            • Rictech
                              Panasonic SA-MAX770PU SMPSU board fault....
                              by Rictech
                              Hello everyone. 😀
                              As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                              Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                              Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                              This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                              There are no devices that have exploded or otherwise show signs...
                              08-26-2024, 01:05 AM
                            • smic717394
                              by smic717394
                              07-25-2024, 10:16 AM
