Samsung 40 inch dark screen
  • singledad30ca
    • Dec 2014
    • 9
    Buddies TV worked great for a while but soon the screen started to darken.
    Now when he turns on the TV the image is dark.
    The model is LE40B550A5
    What could be the problem with his TV?
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: Samsung 40 inch dark screen
    https://www.badcaps.net/forum/showthread.php?t=39740
    please read it may help you more
    • singledad30ca
      • Dec 2014
      • 9
      The image is so dark not worth taking a picture of it.
      Been trying to find info on back light but there is a lot of info on this site.
      • Glitcher
        • Mar 2013
        • 673
        • USa
        Bad panel
        • singledad30ca
          • Dec 2014
          • 9
          Ok thanks
            Not necessarily. Can't see a photo, could it just be backlight going dim? It's rare to get a dim/blur panel failure on a B-series Samsung.
            • nomoresonys
              • 12323
              • U.S.
              if you could post some good clear pics. of the tv with back off, all the boards, makes it a lot easier to help, a pic. is worth a thousand words.
              • nomoresonys
                • 12323
                • U.S.
                be careful around power supply "HIGH VOLTAGE"
                • nomoresonys
                  • 12323
                  • U.S.
                  your saying sound and no picture, if I understand correctly, makes me think something wrong with inverter, maybe.
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • Rozp
                    70LE660U dark cloud or black screen with sound.
                    by Rozp
                    Hello Everyone,
                    This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                    I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                    08-29-2023, 05:25 PM
                  • bohaboha
                    Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                    by bohaboha
                    Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                    anyhow i couldn't t read anything else
                    the backlight is on strong and the screen does not get dark or very dark but no pictures
                    the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                    01-02-2025, 08:04 PM
                  • Chrissygizmo
                    samsung galaxy ao2s very temperamental after screen replaced
                    by Chrissygizmo
                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                    Ive eventually managed to get it on and working but it's very temperamental...
                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                    05-26-2024, 12:05 AM
                  • Topcat
                    Samsung UN75RU7200FXZA - Right 1/3 Portion of Screen Dark
                    by Topcat
                    Set from 2019.....sad this is all they last anymore. Ok, obviously a backlight problem. From what I understand there are 3 strips in these, mounted vertically....one seems to be bad. The image is present behind the darkness, not a LVDS or TCON issue.
                    This TV is a beast. I can't even manhandle it by myself, let alone try and lift the screen out to restrip it.....but I haven't even gotten this far yet....I can't seem to find strips for it.
                    I found a set for the UN75RU7100FXZA but not the 7200.
                    https://...
                    05-29-2023, 08:33 PM
