Re: samsung LN-S4051D diagnal lines
inlets are tiny, multi meter probes wont fit.
But are the conductors still show continuities between each end of the wires?Leave a comment:
http://electronics.stackexchange.com...-or-transistorLeave a comment:
will try my best to figure out how to do it, Thanks budm.Leave a comment:
with only g board hooked up, getting 6.45 on stby, and no other voltages, i think thats normal with just the one board hooked up, now I think I need to jumper my board from stby to p-on, not seeing a ps-on, do I need to leave the jumper connected or is it just touch and release?, Thanks.Leave a comment:
popped in a pr1005, rated at 600, now getting the same .058 both ways in diode, on ohm I get 63.5 and 62.8 in other direction, still trying to wrap my little brain around soldering the cap in parallel on the a board, Thanks.Leave a comment:
I am sure you have some diode in one of the spare boards you have.Leave a comment:
1n4000 series Diode, look up the spec sheet, the 1n4007 has PEAK reverse voltage rating of 1000V (700V RMS).
You can use any rectifier diode with 500~1000V rating in that location.
"I thought all diodes were one way" Yes they are but when they shorted out it will show resistance both way, but that is not the problem with your diode, it is connected in parallel with relay coil that has resistance of around 62 Ohms so it shows up as bad when you check it.Leave a comment:
ok, back at it, just had to add a troll to ignore list, God bless the lonely trolls, with no social skills, not even online, hohoho.Last edited by nomoresonys; 01-02-2015, 12:22 AM.Leave a comment:
sorry you dont have the electronic skills to repair this tv
My advice is to give up and save your moneyLeave a comment:
OK, try soldering another cap in parallel with that cap, anything between 47~100uF 10VDC, the white bar on that cap is POSITIVE so make sure the positive of the added cap goes to that bar side. See if it changes the symptom on the screen.Leave a comment:
So does your main board has this cap on the bottom side?
https://www.badcaps.net/forum/attach...2&d=1420085798Leave a comment:
Well that DS805 (1N4937) is the snubber Diode for the Relay REL801, it is connected in parallel with the relay coil (Omron G5RL 5vdc COIL, about 62 Ohm DCR) that is why it show conduction in both direction, that is why I ask you to take the RESISTANCE reading of the Diode, not in the Diode mode, I get some idea what the resistance is.
When you check semiconductor for shorts, leakage resistance, you use Ohm mode because when semiconductor shorted out it will no longer act as semiconductor.
you can use 1N 4007 in its place. You can verify by check the resistance of the two copper pads where the diode's legs are connected to and see what resistance you get.
BTW, if the power supply is bad it will affect not just the pictures but also other circuits as well.Last edited by nomoresonys; 01-01-2015, 09:13 PM.Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by RubenlilyHello,
First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
I'm no expert but I've done the tape... -
by jeyoung12Hi all
I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
So....i don't know what end of the C ribbon to work with... -
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
