Sony kdl32l4000 tcon or inverter?
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    This set has a punched-in damaged panel.
    Powers on. Mainboard and psu seem OK as I'm able to get sound, remote activity , etc.
    Backlight flashes briefly on power up, but then goes dark.
    I'm wondering if I can somehow test/isolate the inverter and the tcon to know if one or the other is likely OK. Thanks for any help!
  • techman1025
    • Jun 2014
    • 497
    Re: Sony kdl32l4000 tcon or inverter?
    Hi ....known problem JUST REPLACE T401 inverter transformer (PN 1-857-109-11) very inexpensive ..this will fix your problem
    Techman1025
      If the panel is badly damaged a bulb may be cracked... this will cause this symptom.
      • tucocaps
        • Apr 2013
        • 331
        • United Stated
        Does it seem like the TCON is probably OK, but the inverter is damaged, based on the symptom?
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          If screen is smashed--you cant tell about T-Con!--That does the picture, but if panel smashed--you'll not have a picture regardless!
          IF a bulb has gone--will give 2 sec to black regardless of whether the BL board is OK.--Thats to say, the BL board could still be faulty but you'll not be able to tell--IF you've got a broken bulb...
          Then again--IF you plan to fix--You'll be replacing all this lot anyway!.
          TELEFIX
          • tucocaps
            • Apr 2013
            • 331
            • United Stated
            thanks alastair! I guess that's how the cookie crumbles when you have a broken panel. No real way to test TCON, and in some cases the inverter. Well, I heard the inverter can be tested with a bunch of bulbs ... but I'm not sure building that rig is worth it for me just yet.
            • lookimback
              • Aug 2013
              • 1489
              These older Sony's also have protection circuits. So, you could have a fault on any of the boards and still have the backlights fire. They should attempt to start 3 times, and then the LED will flash a code and the TV will go into protection mode. At that point, you have to disconnect the power source to reset.
              ------------signature starts here------------
              • tucocaps
                • Apr 2013
                • 331
                • United Stated
                kimback: Well, this one isn't going into protection mode. Also, I've found in most cases that the TCON is OK when the screen is cracked. However, I'm now realizing that I am making a pretty big assumption there. Even so, I've sold several from cracked screen units, and no complaints yet. Got a bunch on the shelf too.
                • lookimback
                  • Aug 2013
                  • 1489
                  In my experience, even with a broken screen, it's (usually) possible to determine whether a Tcon is good or not. Of course, you can't test it 100%. Usually, unless you have a straight horizontal crack across the top (or bottom if that's where the TABs are), you can see enough of the picture to make an educated guess. That's saying, your average accidental damage, not the "I got into a fight with my gf and she smashed it with a hammer." (I've seen a few of them too).
                  • tucocaps
                    • Apr 2013
                    • 331
                    • United Stated
                    kimback: that's a good point, and I've definitely tried to see what I can see with a cracked screen that's still "working". However, if I understand this right, if there is major screen damage and the BL won't stay on, then you are probably looking at a broken bulb. In that case, you can only "bench test" the inverter (with lamps), but can't really see anything regarding the TCON?
                    • lookimback
                      • Aug 2013
                      • 1489
                      Yes, you are correct. With no backlights, there's not much you can do. Depends on the design, but sometimes you can manually turn the inverter on using a 5k resistor, just as you would jump ps_on. On the older Sony's (not sure about newer ones), what's often mistaken for inverters are actually balancer boards, and the transformers which power them are usually on the PS or, in some, are on separate boards.
                      • Daren87
                        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                        by Daren87
                        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                        08-13-2023, 03:25 PM
                      • iglitare
                        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                        by iglitare
                        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                        Backlight seems to work, Sound (Setup menu after reset) works.
                        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                        With my small knowledge i would think at least the cables are good.
                        Can this happen because of a bad tcon board?
                        Or is it always a bad/shorted...
                        09-04-2025, 07:13 AM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • rimwall
                        Sony KD-65x7500D - double image - Tcon or Panel?
                        by rimwall
                        This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                        I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                        11-18-2025, 02:09 AM
                      • thelankanguy
                        Sony KD-55X9000F TCON Issue
                        by thelankanguy
                        The TV shows a black screen with no image.
                        TCON ribbon connectors were disconnected individually for image and there was no half image even.
                        Later both ribbons were disconnected and TCON voltages were tested.
                        12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                        There is also a short to ground in this circled inductor.
                        Is this a TCON issue or something else ?...
                        12-13-2024, 12:27 AM
