Hi! Well, the orange standby light comes on and changes to white on power up. I can't see any backlights at all. The PS board fuse checks good as well as the two SMD type fuses near J1. The unit will power off, making me think it may not be a U33 failure. All the mainboard caps are Tiacon and CE3 has a corroded cap. My question is, should I pull the mainboard and replace the cap OR check more voltages before continuing? Noob question, sorry.
Vizio VW37LHDTV10A no backlight
Tags: None
Re: Vizio VW37LHDTV10A no backlight
Pictures of the whole back side of the TV and the boards.
We need to find out if we have 24VDC, BL_ON signal or not.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Ok. Here we are. Thought it was unusual that the "CPU" had no heatsink.Attached Filesif you find these attachements useful please consider making a small donation to the site
So you need to check the signal pins on the power supply board when TV is OFF and when TV is turned on:
PS_ON pin.
A pin
B pin
C pinNever stop learning
Sorry for the slow reply. In standby they all read zero, ON they were PS_ON 3v, A 2.6v and B .03v ; as far as I can tell.Comment
Also, none of the pins on the 24vdc plug read anything close to 24vdc.Comment
OK, we need to find out if the PFC Voltage booster circuit is working or not next.
You will have to be real careful since you will be making measurement in the deadly PRIMARY side of the circuit. You will be measuring the Voltage RIGHT AT THE TWO LEGS OF THE MAIN FILTER Cap, it is the big cap laying on it side, it should have about 160VDC when the TV is not turned on and then it should jump up to >360VDC when power switch is activated and the main board sends out the PS_ON to turn on the PFC Voltage booster circuit and the 12V/24V Power supply section.
Do not let your hands or body touch anything on the board.Never stop learning
OK, that is why you are not getting the 12V/24V because the 12V/24V power supply section requires that boosted Voltage to run.
You may want to look for another power supply board from shojimmy at this point, to fix to component level is not going to be easy dealing with SMD parts.
Beside this power supply board, we do not know if all the regulators ICs are all good or not on the main board until you get the power supply running first.
Power supply:
http://www.shopjimmy.com/vizio-0500-...upply-unit.htm
He is having 5% of for December.Last edited by budm; 12-18-2014, 12:23 AM.Never stop learning
Alrighty then, I will get a PS. Thanks for the help, Mr. BudM.Comment
I replaced the power supply board and it's doing pretty much the same thing as before. Any ideas?Comment
PS_ON is still at 3VDC? The voltage on the main cap still did not go up to >360VDC?
Did you get the board from SJ?Never stop learning
Yes, still 3vdc, no change on main cap, EbayComment
The one from SJ isn't working either. The power board is not the problem.Comment
ok, did you try just unplug the connector for bl-on, see if the backlights come on?Comment
If you have PS_ON but no boosted Voltage on the main cap, then the power board is still not right, there is nothing else that the power supply will need to get the boosted voltage.
You can run the power supply board by itself and use force on signal on the PS_ON pin.
http://s807.photobucket.com/user/bud...?sort=3&page=1Last edited by budm; 01-03-2015, 10:20 PM.Never stop learning
Assuming...7 Photos -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by YanlebI have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've... -
by alro7779Hello, guys!
I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
Alex.... - Loading...
