Hi! Well, the orange standby light comes on and changes to white on power up. I can't see any backlights at all. The PS board fuse checks good as well as the two SMD type fuses near J1. The unit will power off, making me think it may not be a U33 failure. All the mainboard caps are Tiacon and CE3 has a corroded cap. My question is, should I pull the mainboard and replace the cap OR check more voltages before continuing? Noob question, sorry.
Vizio VW37LHDTV10A no backlight
Re: Vizio VW37LHDTV10A no backlight
Pictures of the whole back side of the TV and the boards.
We need to find out if we have 24VDC, BL_ON signal or not.Never stop learning
So you need to check the signal pins on the power supply board when TV is OFF and when TV is turned on:
PS_ON pin.
A pin
B pin
C pinNever stop learning
Originally posted by Brian with a/b View PostAlso, none of the pins on the 24vdc plug read anything close to 24vdc.Never stop learning
OK, we need to find out if the PFC Voltage booster circuit is working or not next.
You will have to be real careful since you will be making measurement in the deadly PRIMARY side of the circuit. You will be measuring the Voltage RIGHT AT THE TWO LEGS OF THE MAIN FILTER Cap, it is the big cap laying on it side, it should have about 160VDC when the TV is not turned on and then it should jump up to >360VDC when power switch is activated and the main board sends out the PS_ON to turn on the PFC Voltage booster circuit and the 12V/24V Power supply section.
Do not let your hands or body touch anything on the board.Never stop learning
OK, that is why you are not getting the 12V/24V because the 12V/24V power supply section requires that boosted Voltage to run.
You may want to look for another power supply board from shojimmy at this point, to fix to component level is not going to be easy dealing with SMD parts.
Beside this power supply board, we do not know if all the regulators ICs are all good or not on the main board until you get the power supply running first.
Power supply:
http://www.shopjimmy.com/vizio-0500-...upply-unit.htm
He is having 5% of for December.Last edited by budm; 12-18-2014, 12:23 AM.Never stop learning
PS_ON is still at 3VDC? The voltage on the main cap still did not go up to >360VDC?
Did you get the board from SJ?Never stop learning
If you have PS_ON but no boosted Voltage on the main cap, then the power board is still not right, there is nothing else that the power supply will need to get the boosted voltage.
You can run the power supply board by itself and use force on signal on the PS_ON pin.
http://s807.photobucket.com/user/bud...?sort=3&page=1Last edited by budm; 01-03-2015, 10:20 PM.Never stop learning
