Panasonic th-p42x10z Can't be turned on twice in a row?! Power first time,not second?
  • gunit1234
    • 15
    • New Zealand
    Hi guys! Thanks in advance for the help!
    SYMPTOMS:
    TV was working fine until going into storage in the garage for 6 months. Possibly a little cold and damp, but nothing beyond usual. Now, TV will turn on no problem but upon turning on a second time, will not power up – just green LED then straight to blinking either 2 or 3 red blinks (seems to randomly be either code).
    If I disconnect the TV for 24 hours and let discharge, can then plug in and turn on no problem. But if turning off after 10 sec or half hour (does't seem to make a difference), will not be able to turn on again. Same blinking red LEDs. Seems to be related to the A-board according to the blink codes.
    SERVICE MANUALS:
    I cannot find the exact service manual. I believe this is an Australia/New Zealand model, maybe named something else in other areas. This is the closest I could find that looked like the same layouts:
    1) http://www.toms-service-manuals.com/...&mfg=Panasonic
    OR Perhaps
    2) http://elektrotanya.com/panasonic_tx.../download.html
    WHAT I'VE TRIED:
    1. Done a basic resistance check on the 3 fuses I could find on the power board. Seem kosher.
    2. Looked for bad caps. Can't find any swelling on any board (though I know they're not always visibly broken).
    Also note some cables have already been unplugged so I could check under the A-board.
    I should mention I'm only starting to get into this stuff, have fairly basic knowledge, but am willing to research and learn. That's why I'm here (but also because I wanna get my TV back haha ).
    THANKSSSSS
    Gil
    Ps. This is a repost. Realised that no description means no traction. Won't happen again!
  • tw2005
    • Oct 2011
    • 6457
    Re: Panasonic th-p42x10z Can't be turned on twice in a row?! Power first time,not sec
    ........Realised that no description means no traction. ...........
    No, I disagree. Random intermittent and variable faults are pretty hard to fault find. I'm thinking since it was stored and damp I'd be reseating all the acles and if you have a magnifier, unplug the white ribbons and have a real close look for corrosion. I had a 42X20 and the copper had blued, corroded and was shorting. had to replace the ribbons from a salvaged TV.
    Not a fault i've read about so tough one to help with, maybe A board??
    • gunit1234
      • 15
      • New Zealand
      Hey buddy
      Can you please briefly explain what "reseating all the acles" means? Also I don't know what you mean by "no, I disagree".
      Thanks!
      • tw2005
        • Oct 2011
        • 6457
        refer quotation, I don't think a repost was necessary or it was lacking traction. Unusual fault though.
        "reseating all the acles" = cables, that's what happens when you're hopeless at typing and rushing out the door. Sorry about that.
        • gunit1234
          • 15
          • New Zealand
          Yeah fair call. Sorry about that. Next time I won't do it
          UPDATE:
          I found someone with an identical TV and swapped my A board with his. The problem disappeared on mine and was transferred to his TV.
          So it's definitely something to do with that board. Does that lead you to any other potential conclusions?
          Thanks again!
          • tw2005
            • Oct 2011
            • 6457
            UPDATE:
            Thanks again!
            Can only guess really, bad caps , who knows, heat related fault? Dirty contacts on the A board?
            • gunit1234
              • 15
              • New Zealand
              Ok well, I just emailed ShopJimmy to see if they have the part. Anywhere else that's worth looking? Need to send it to New Zealand of course. Thanks a bunch tw2005!
              • tw2005
                • Oct 2011
                • 6457
                I'd be amazed if a US board would be the same or work in NZ. A NZ board won't work in AU for tuning and vice versa
