SHARP lc60e79u 60 INCH LCD TV NO PICTURE NO SOUND
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Re: SHARP lc60e79u 60 INCH LCD TV NO PICTURE NO SOUND
    i saw this online....my tcon is mounted on bottom of tv not top also
    Video Goes Bright White : Washed Out Looking Intermittently Tapping Or Twisting The Panel May Affect This Symptom. This Model Has The T-Con Mounted To The Bottom Of The Lcd Panel. The 2 Ribbon Cables From The T-Con Are Connected To 2 Thin Circuit Boards That Run Along The Lower Edge Of The Lcd. Because These Are On The Lower Edge, The Weight Of The Panel Can Press Them Against The Metal Frame Around The Screen Causing Them To Short Out And Give The Symptom Descibed Above. We Have Found Inserting A Thin Strip Of Cardboard Or Index Card Strips Between The Circuit Boards And The Metal Frome Will Isolate Them And Prevent This Problem
    SAMSUNG LCD LN32A450C1D
    Very bright white screen with washed out negative picture This set has a very bright screen (white) The screen is washed out with a neg pic. Samsung's web site mentions a board that the SMD caps are shorting out to the frame. The board is apparently between the LCD panel and the T-con board. The problem was indeed the bottom frame touching the SMD's on the two circuit boards that are connected to the LCD panel. If you look closely, you can see that the bottom frame is slightly bent upwards towards the PC boards. Putting in two 8 inch by 11/4 inch pieces of cardboard between the boards and the metal frame rectified the problem.
    • shelby5041
      • Feb 2009
      • 1505
      any opinions on what i found online would be appreciated
      • shelby5041
        • Feb 2009
        • 1505
        well i tried on idea of flipping tv upside down to take weight of tv off of panel boaeds and ribbons....no change at all..
        • shelby5041
          • Feb 2009
          • 1505
          hi any feedback on what issue could be with my tv....the display is not working correctly
          see photos...i changed tcon and no change at all
          its a nice tv and want to fix it if possible
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • jchang
            Samsung UN70NU6900F no picture and no sound
            by jchang
            Hi all
            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
            Symptom:
            No picture no sound.
            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
            No sound at all.
            What I tried:
            1. I tried unplugging the left or right ribbon...
            01-09-2023, 06:28 PM
          • JohnML1975
            Samsung UA50TU8000W no picture and no sound
            by JohnML1975
            Hello All
            have seen posts on this model in here but my problem sounded different so thought i would create a thread
            TV will not turn on
            There is no standby light
            When I press ON button for remote the red standby light does flash but no picture and no sound
            From the back of the TV I can see the red light on the back of the mother board
            Holding torch to the screen I cannot see a picture
            I removed the back cover
            Observing the boards I cannot see any damage
            I disconnected the main board from the power supply
            the back...
            08-30-2025, 09:40 PM
