My friend gave me a olevia 242tfhd cause he bought a 50inch tv on black Friday, He said it didn't turn on so i took it apart and behold there was about 5 bad caps on the psu, So i switch them out with radio shack ones that look like blue and ony 85c instead of 105c and the old ones was 105 and 35v 560uf vs the radio shack 85c 35v 1000uf.. ...Yea i know its best to order the best ones online..
But at the time i couldn't order online for other reasons, So i figure i give the radio shack ones a try, So i pop them in and everything turns on and works perfect!!! So for the pass week i been using this tv as a monitor for my computer.
And wow this screen does have a really nice pic and bright so im loving it, But i been noticing alot of image burn in which is image retention for lcds. It gets it alot like if i leave it on desktop for i say about 5 to 10mins you can see the icons still on dark colors like greys.. pretty much anything that doesn't move it will show it for a bit..
It does go away tho if i put a white screen up or play something with movement or even turning it off for awhile.
So i was wondering can using the wrong caps cause this issue? i always herd you can use higher voltage and higher uf than the old cap. I mean everything is working as it should but this is the first lcd i ever had this much image retention.
Ony lcd i experience it with but not as bad is my old 2007 dell 20.1w ips monitor which is like 8 years old now and has about 70k hours on the clock. But i just took it because its just ageing.
