sony KDL-46S4100 firmware
  • nomoresonys
    • 12274
    • U.S.
    hello, does anyone have or know where I can download firmware for sony KDL-46S4100, the sony website doesn't seem to have it and I can't locate any archives, THANKS.
  • nomoresonys
    • 12274
    • U.S.
    Re: sony KDL-46S4100 firmware
    guess the firmware is too hard to find, does anyone know how to match up the g board a board and tcon with my panel, panel # is LTZ460HB10, Thank you for helping, I'm technically challenged, lol.
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
    • joby91
      SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
      by joby91
      I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
      I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
      I found one chat about firmware on ************** forum but i cannot read the comments.
      https://**************/forum/108-114100-1#880537
      09-04-2024, 01:34 PM
    • jason123
      Sony Firmware for XBR-70X850B
      by jason123
      Hello
      Help is much appreciated. I have a Sony XBR-70X850B with bad main board. I got a mainboard for it, but as you know I have to update the firmware on this TV for the main board to work.
      I went to the Sony website, and I can't seem to find the Firmware file. Sony is no longer making this available.
      Does any of you have firmware / software files for this TV that I can put on USB for update to make this main board work?
      Much appreciated.
      05-17-2022, 12:42 PM
    • AlexWhat
      SONY KDL-65w850c need latest firmware 6.827
      by AlexWhat
      In 2022 SONY did "Termination of TV Software Update" for this model.
      I did find older firmware but it can't be installed over newer one (rolled back)
      Yes, got boot loop during android load so if that will not work then EMMC has to be replaced, I think.
      12-15-2024, 11:32 PM
    • cheeky2
      Help with Sony firmware KDL-40W5500 v1.752EA
      by cheeky2
      Unfortunately Sony Have taken all there old TV firmwares down from there website last year. So it isn't available to download. Does someone have the firmware available please? It is used for a whole range of the KDL range of TV's including the following models :
      KDL-22E5300, KDL-22E5310, KDL-32E5500, KDL-32E5510, KDL-32E5520, KDL-32V5500, KDL-32V5610, KDL-32W5500, KDL-32W5710, KDL-32W5720, KDL-32W5730, KDL-32W5740, KDL-37V5500, KDL-37V5610, KDL-37W5500, KDL-37W5710, KDL-37W5720, KDL-37W5730, KDL-37W5740, KDL-40E5500, KDL-40E5510, KDL-40E5520, KDL-40V5500, KDL-40V5610, KDL-40W5500, KDL-40W5710,...
      01-28-2023, 06:13 PM
