LG Plasma model 42PC3D Repaired Y-SUS but still have an issue
  • aaronwt6
    • Apr 2013
    • 855
    • US
    I believe I already know the answer on this but wanted a 2nd opinion. Guy brought this TV to me to repair. It has the 42X3 series PDP and I've fixed plenty of these. Powered up and it had the typical no picture but sound working. So, immediately I know the IPM on the Y-SUS is blown. Took apart, verified it was bad, and changed the IPM and the blown fuse. Powered up and have the result in the pictures. I'm assuming the X-SUS has also got an issue but there are no shorts on it that I can find and the fuse is ok. I've never encountered one of these with a problem on both boards and not sure the guy is even going to want to dump any more money on it. I've got a couple hours in to it now plus a $35 IPM and still no working TV. Thanks as always for anyone's help / comments. Aaron
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: LG Plasma model 42PC3D Repaired Y-SUS but still have an issue
    Oh, and I'm quite confident in my Y-SUS repair unless the new IPM has a problem. I've fixed at least 20 of these boards.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Any opinions on this? I'm kinda wondering if it could be a voltage issue. The screen was very bright and the bad X-SUS boards I've seen on this usually cause it to be dim. I'll be home later this evening to toy with it some more.
      • mmartell
        • Oct 2013
        • 3189
        I believe there is a 15v or maybe 18v line produced on the ysus that gets routed through the control board and used on the zsus ipm. Verify that it is present on the zsus. I had a similar situation after repairing a zsus ipm only to find the cable from the control board became unseated enough from plugging/unplugging at the zsus to remove the 15v line.
        • aaronwt6
          • Apr 2013
          • 855
          • US
          Thanks mmartell. I will check that out this evening. Verified that all the voltages were correct and matched the panel label last night but I'll look in to the connections on the logic board.
            Do you have a scope available?
            • aaronwt6
              • Apr 2013
              • 855
              • US
              Sure don't Tom. I've been considering picking one up at some point with all the repairs I've been doing but the budget hasn't allowed for it. I do have a spare of each part for this TV other than the X-SUS and Y-SUS. Obviously a known working X-SUS board at this point would be nice to rule that out. Like I said, in my experience with TVs containing this panel, the bad X-SUS typically creates a very dull lit screen. This one is certainly not acting that way.
              • aaronwt6
                • Apr 2013
                • 855
                • US
                Checked voltages out last night on this. Everything was pretty close to the panel specs. I think I may try a different logic board in it simply because I have one on hand. I noted last night that with no input connected the screen is approx. 90% pure white with small moving black blobs appearing randomly at times. Of course, the screen should be black with the no signal message. That in itself is making me think it has a control issue. I'll update when I have more time to tinker.
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  Tom, if you don't mind too when you get a chance; Could you recommend a scope for me? Certainly don't need anything over the top on price but just whatever you would think is adequate.
                  Thanks as always,
                  Aaron
                    What's your budget?
                    A scope suitable for most plasma repairs could be had for under $50.
                    Some high speed stuff, or more detailed diagnosis, can't go wrong with the Rigol DS1054Z. ($399 - put it on the xmas wish list...) fully digital so can play/pause and capture glitches etc., very useful for tracking down intermittent faults. The DS1054Z can also be upgraded to the DS1104Z with all options including deep memory through a simple trick.
                    I have a top spec DS1074Z (70MHz variant, upgraded to 100MHz; bought it before 50MHz was an option)
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      I was considering possibly going up as high as $500 if I had to. Really didn't know I could get something adequate for under $100 though. Sounds very encouraging.
                        Well, as I said, it will be a basic analog scope for $50~$100 (that would be a second hand price) so you have no advanced triggers, play/pause etc. but it can be used to check if the Z-sus and Y-sus outputs look approximately OK but you will have to make do with an unstable display due to lack of suitable triggers.
                        If your budget does go $400+ the Rigol will not steer you wrong, it's an excellent beginner and mid-class instrument. Since it has a ramp and pulse-width trigger, it allows you to trigger on the Y- and Z-sus outputs. Plus you can set it up to record, and play back glitches later, if you have e.g. a TV that blanks out once every hour, it'll capture that.
                        • aaronwt6
                          • Apr 2013
                          • 855
                          • US
                          The DS1054Z looks really nice. I don't know if anyone can swing that for me for a present but I'm going to consider it in the near future. Thanks again for the recommendation.
                          If I'm going to buy one, I'd certainly like it to do everything it needs to. I always hate the feeling of, 'oh, I wish I had gotten something better'
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            If you can find one--One of the Tektronix 24xx series would be good....
                            I got one fairly recently --a Tek 2465 450MHz, 4 ch, with cursors and other toys that cost me £15, Had a simple fault--Caps in the PSU which let go the first time I fired it up. --Mains-filter cap, one of those 'RIFA' ones that go smoking....
                            TELEFIX
                              Yes, a very nice scope. Very heavy, though!
                              My first scope was a HP54501A... but I regret buying a cheap digital HP... I should have bought the Philips PM3394 next to it for the same price.
                              • aaronwt6
                                • Apr 2013
                                • 855
                                • US
                                I'll take a look at those as well. Juts read through the PDP guide in your sig. Quite interesting. Just makes you realize how little it takes to have a problem on any piece of electronics. Not to mention the amount of time and knowledge that goes in to the development.
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  Heavy......
                                  Nah--It aint heavy, Not in comparison to my old Tek 454 150MHz dual-channel...
                                  --That has Valves in it--well, tiny ones called Nuvistors--All you guys prolly never seen or heard of Nuvistors...Marvellous things!.....
                                  Even managed to get a brand-new CRT for that old 454, but these days,--its showing its age in other ways, needs some serious work to the sync and timebase stages--at least the trace is very bright and sharp though, when it does sync up
                                  TELEFIX
                                  • ANDRASONI LUCIAN
                                    • May 2012
                                    • 56
                                    • Romania
                                    Check the ZSUS board, change electrolytic caps.From Romania, all the best!
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      Recently, I had a similar looking fault on an LG 50PK590....
                                      The SET_Up preset did absolutely nothing, and the MOSFET associated with the SET_Up was stone cold.
                                      I traced as far as I could with the drive to this device,--which appeared to be present, but the SET_Up ramp part of the Y-SUS wave was distorted and not very high amplitude.
                                      Tracing back from the gate connection there was a circuit comprising a couple of transistors, and a couple of opto-couplers.
                                      All these devices appeared good. I couldn't go much further as I had no schematic--as none is available....
                                      As the Y-SUS was dirt cheap, I replaced it complete--which solved the problem...
                                      On the replacement board, That said same MOSFET for the SET_Up ramp--was the hottest on the board......
                                      TELEFIX
                                      • PlasMatt
                                        LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                        by PlasMatt
                                        I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                        09-20-2025, 06:50 PM
                                      • Cooperr
                                        Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                        by Cooperr
                                        I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                        The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                        10-21-2025, 01:11 PM
                                      • celiabrown
                                        Issue with Plasma Philips 37inch chassis FTL2.1
                                        by celiabrown
                                        Hello guys,
                                        My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                        Can someone has any symptom like this ?
                                        Thanks​
                                        05-09-2024, 10:56 PM
                                      • rounin
                                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                        by rounin
                                        🛠 Original Issue
                                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                        04-19-2025, 01:18 AM
                                      • gurj1979
                                        MacBook Pro 820-01987- condensation damage repaired but has sensor issue
                                        by gurj1979
                                        Hi guys.
                                        Got a customer MBP 2020 which has a dad of corrosion from condensation, resulted in no power at all.
                                        I replaced the corroded components and repaired the traces. Restored power and now Iccan get to login screen.
                                        But when the CPU gets warm (not hot) and fan gradually starts spinning faster and then MBP turns off. Pressing power button turns it back on for couple of seconds then it turns off again.
                                        Seems sensor related, but it won't even let me get as far as running the built-in ASD.
                                        I can get back to you later with the components...
                                        08-01-2023, 02:38 PM
