Panasonic TNPH0716 repair, anyone know what's wrong?
  • videotronics
    • May 2013
    • 22
    Re: Panasonic TNPH0716 repair, anyone know what's wrong?
    Can someone help me locate IC4511, Gordon
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      #42
      It's on the back of the mainboard. See pics.
      • videotronics
        • May 2013
        • 22
        Thank you
        • videotronics
          • May 2013
          • 22
          I found a repair kit on eBay, while awaiting a reply from the seller to my query “ is ic4511 included?” I ask the technicians of badcaps to help me locate a distributor for the part, Gordon
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            #45
            The device appears to have the Microchip logo stamped on it but I can't find any information on it.
            • videotronics
              • May 2013
              • 22
              Fuses good, plug in standby 5v good, power on power supplies good, display dimly lit, no response to menu button, looking at the mainboard, read johnboy1313’s post on the mainboard regulator IC4511, measured input pin 1 to ground shorted, now I seek a replacement IC4511. Printed on the case: a stylized capital M logo of Microchip Technology 751 and 563D in a 7 terminal smd case, I have a photo, Gordon
              • R_J
                • 9556
                I believe pin #1 is the output pin (3.3v), pin #7 is the input (5v)
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #48
                  It may not be the IC Pin 1 shorted to ground but something connected on the output tracks.
                  This looks like the pinouts of the IC even though it could be wired differently on your circuit
                  The logo is in fact Mitsumi and not Microchip as I first thought.
                  This looks like the full part number MM1563 563D
                  The part appears to be obsolete but I am sure you could modify it and fit a 5V to 3.3V regulator in its place.
                  • videotronics
                    • May 2013
                    • 22
                    We agree, a shorted component on the 3.3v line from IC4511 pin 1. In previous decades I read manufacturer service bulletins and repair history notes, tracked the short lifting leads and cutting traces, typically I would find a shorted IC or rarely a shorted capacitor, anyone have a TNPHO716 schematic and notes on dimly lit display, no menu?
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                      11-20-2024, 08:52 PM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • Mnawar27
                      Panasonic CF-H2AU24EF3 bios locked
                      by Mnawar27
                      Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                      I need help to remove it,
                      thankyou all.
                      SN; 2FKCA26876...
                      11-16-2024, 08:00 AM
                    • Yanleb
                      Panasonic part number in service manuals
                      by Yanleb
                      In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                      This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                      For an example, look at the attached PDF.
                      Do you have a way to cross reference the Panasonic part number with the actual part number?
                      Thanks....
                      07-03-2023, 08:16 PM
                    • AquaMan Ua
                      by AquaMan Ua
                      05-17-2025, 09:40 AM
