Lg 42ld490-zb
  • sordids999
    • May 2013
    • 2154
    Lg 42ld490-zb
    Hi guys
    just wondering if anyone has seen this fault before i cant post pictures until tomorrow of the boards due to not picking it up until then but i can post a screen shot of the screen
    thanks
    Re: Lg 42ld490-zb
    The one thing it reminds me of is a 720p main board being installed in a 1080p TV. Since the system menu would appear inaccesible, it would be quite hard to reset (short of installing a new board)
    • sordids999
      • May 2013
      • 2154
      Re: Lg 42ld490-zb
      ok thanks m8 ill post some pictures tomorrow
      • sordids999
        • May 2013
        • 2154
        Re: Lg 42ld490-zb
        right pictures uploaded i have tested the tcon voltages which are fine
        voltages are good as well
        NC 0.00 ERRON 0.00
        12v=12 volts P-DIM=1.0 volts
        12v=12 volts A-DIM=1.4 volts
        12v=12 volts INV ON/OFF 2.8 volts
        GND GND
        GND GND
        3.5v=3.2 volts 3.5v=3.2 volts
        GND GND
        GND GND
        20v=20.6 volts 20v=20.6 volts
        20v=20.6 volts POWER-ON 3 volts
        thanks
        • sordids999
          • May 2013
          • 2154
          Re: Lg 42ld490-zb
          update: if i use a hair dryer on IC100 then the image comes back it seems once warmed up
          so question easy to change ?
          struggling to find a replacement board anywhere though
          • sordids999
            • May 2013
            • 2154
            Re: Lg 42ld490-zb
            picture uploaded
              Re: Lg 42ld490-zb
              Not at all easy to change. You could perhaps get it reballed if you know someone with the gear, similar repair to Xbox360/PS3 lights-of-death symptom.
              • freakaftr8
                • Oct 2012
                • 3743
                Re: Lg 42ld490-zb
                I've had some luck reballing and using a hot air rework station that I have. I've had hit or miss issues with the older lg 720p plasma logic boards when the blue red and green vertical bars that show up. But it's iffy. You could always try if you knew someone that had a rework station if not just buy a new board
                • sordids999
                  • May 2013
                  • 2154
                  Re: Lg 42ld490-zb
                  thats the problem im struggling to find one though
                    Re: Lg 42ld490-zb
                    If you can't find an exact board, it might be possible to swap over that flash chip with the sticker on it, to the new board. This would essentially convert one board (even if it was, e.g. a 32" 720p board) to the same specification as your new one. Does require things like HDMI ports to be the same though, so watch out.
                    What are the part numbers EBR/EAX you are looking for?
                    • sordids999
                      • May 2013
                      • 2154
                      Re: Lg 42ld490-zb
                      Eax61531909(2)
                        Re: Lg 42ld490-zb
                        I will check my pile, though I don't recall tearing down one of these. I can ask a friend if they have one in their respective pile.
                        • sordids999
                          • May 2013
                          • 2154
                          Re: Lg 42ld490-zb
                          thanks m8
                            Re: Lg 42ld490-zb
                            No match in my pile, sent a text to a friend, but will have to see what he says in the morning.
                            • sordids999
                              • May 2013
                              • 2154
                              Re: Lg 42ld490-zb
                              So due to still not finding a mainboard for this tv i done a reflow today and the tv is now working fine,so anyone had any experience how long this will last until i find a replacement board ?
                                Re: Lg 42ld490-zb
                                I had one reflow on my graphics card last a month. Some have lasted years, others only days.
                                • sordids999
                                  • May 2013
                                  • 2154
                                  Re: Lg 42ld490-zb
                                  ok thanks tom just wanted a rough idea first time i tried this so was unsure
                                  • Ciri781
                                    • Jan 2020
                                    • Gb
                                    Re: Lg 42ld490-zb
                                    Hi guys
                                    Anyone have a schematic for eax61531909(2) please?
                                    • Ryan.man
                                      by Ryan.man
                                      02-04-2025, 12:23 PM
                                    • valvashon
                                      LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                      by valvashon
                                      The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                      Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                      11-24-2024, 12:08 PM
                                    • reformatt
                                      by reformatt
                                      07-31-2025, 08:37 PM
                                    • smic717394
                                      by smic717394
                                      07-25-2024, 10:16 AM
                                    • bohaboha
                                      Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                      by bohaboha
                                      Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                      anyhow i couldn't t read anything else
                                      the backlight is on strong and the screen does not get dark or very dark but no pictures
                                      the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                      01-02-2025, 08:04 PM
