Samsung PN64D700FF Line in picture
  • Gadjet
    • Aug 2012
    • 248
    Wondering if this line looks to be a panel problem or something else? Has come before and gone away in a few hours. This time it's been around for a week.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung PN64D700FF Line in picture
    yes that very well could be a panel issue or if you're lucky it could be a faulty ribbon connection from the Y sustain buffer board to the ribbon on the panel you could try to reseat the ribbon cable to see if the problem disappears.
    unfortunately is problem has it these issues seem to be arising more and more with Samsung panels. I've worked out a few with this issue unresolved something is not making a good connection from the ribbon cable inside the PDP glass panel itself.
    hopefully it's just a bad connection considering that that's the 64 inch and I've seen that TV and it has an awesome picture. My father has one crossing my fingers lol
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      By all accounts--The 'D' series Sams. do have more than their fair share of panel issues.
      If re-seating that panel tab that's in line with the faulty portion of the picture, then its likely the panel itself or the bond between the panel and the tab is faulty--You Could get lucky and have a dry-joint on the buffer, but less likely than the panel/tab.
      --These panel/tabs are unrepairable sorry to say....
      TELEFIX
        It might be possible to replace the ribbons but will require some precision alignment. On an LG plasma I had, the ribbons were glued on the outside of the panel. You could lift the ribbon off with a hot air gun, and in theory reseat it on top of the exposed conductive glass portion... but it would be an extremely difficult job to do right.
        • Gadjet
          • Aug 2012
          • 248
          Well Thank You all for your quick replies, I'll try your suggestions and see what happens.
          • NWArkGuy
            Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
            by NWArkGuy
            Well, I will be the first to admit that I screwed up...
            In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
            I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
            I have 2 that I have found and have in my possession. ...
            10-12-2023, 10:13 PM
            09-07-2024, 05:50 AM
          • maneatingmonkey
            Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
            by maneatingmonkey
            I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
            There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
            03-27-2024, 07:17 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
