Samsung LN32C540F2DXZA: Won't turn on, PS and Inverter OK
  • beedoola
    • Dec 2012
    • 35
    Re: Samsung LN32C540F2DXZA: Won't turn on, PS and Inverter OK
    Originally posted by myfastgti
    Yes its a 8 pin dual n-channel mosfet from Alpha and omega number AO4800BL or AO4801. There should be 12 v or 11.8 v at pins 5,6,7 and 8 when the power button is pressed. If not check if you have any voltage at pin 2 and 4.
    Usually these fet's don't fail but so far I've only seen one failure
    I get 12V on 2, nothing on Pin 4.
    3.3v on 5&6, nothing on 7 and 8.
    It is a 4801A BADD1B
    • myfastgti
      • Aug 2014
      • 32
      You could try replacing the FET, eBay sells them for $2.
      Unfortunately I don't have the service manual
        How about pin 1 (Source 2), pin 3 (Source 1)? Those two pins are fed with Voltages which will go out on the Drain pin 5 & 6 for Drain 1, and 7 & 8 for Drain 2.
        The Gate pins (pin 2 for G2, pin 4 for G1) Voltage has to be at least 2V less than the Source pin for the MOSFET (P-CH) to turn on.
        A4801: Dual P-CH MOSFETs
        Pin 1 = S2
        Pin 2 = G2
        Pin 3 = S1
        Pin 4 = G1
        Pin 5 = D1
        Pin 6 = D1
        Pin 7 = D2
        Pin 8 = D2
        • beedoola
          • Dec 2012
          • 35
          S2/Pin 1 also had 12, like Pin 2. Pin 3 had nothing. Where can I find a AO4801?
          • beedoola
            • Dec 2012
            • 35
            Is it possible to jumper the pads to see if I can get proper power to the board?
              The readings you provided does not indIcate bad IC.
              G2 has to be 10V or less for the MOSFET 2 to turn on, and you did not indicate any inout Voltage feeding S2 pin 1 either.
              S1 pin 3 also no Voltage input either.
              • beedoola
                • Dec 2012
                • 35
                Can it be assumed that since the voltages on the PS board are fine and the backlight comes on that the PS and inverter are OK and that the problem must lie somewhere on the Main Board?
                  Yes, as indicated in post 8 that the main board is not sending the signal (PS_ON line stuck low) to turn on the power supply.
                  • beedoola
                    • Dec 2012
                    • 35
                    got a replacement main board for $65 shipped so I'll see how it goes.
                    • Asraf Atb
                      by Asraf Atb
                      01-27-2025, 05:02 PM
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • ygorsan
                      by ygorsan
                      🧩 Problem Summary:
                      • I
                      07-28-2025, 08:34 AM
                    • Lee M.
                      Samsung UN75RU8000FXZA bad main board?
                      by Lee M.
                      When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                      11-08-2023, 07:46 PM
                    • jb_Bak
                      by jb_Bak
                      CN6401
                      Pin 01 NC
                      Pin 02 NC
                      Pin 03 "BL_ON": 0V
                      Pin 04 "N/C"
                      Pin 05 "STBY 3.3V": 3.5V
                      Pin 06 "GND": N/C
                      Pin 07 "AC_OFF"...
                      09-27-2021, 04:52 PM
