Sony Bravia KDL-40W5500 led flashing 13 times
  • mikcatta
    • Nov 2014
    • 7
    Hi
    I understand from reading other forums that this could be down to a faulty CCFL tube.
    Is it possible to purchase replacement tubes?
    Regards
  • Ralph Green
    • Feb 2013
    • 66
    Re: Sony Bravia KDL-40W5500 led flashing 13 times
    Yes, you can buy a new tubes.
    • tibimakai
      • Jan 2012
      • 3680
      Need to measure the glass length and look around here: http://www.ccflwarehouse.com/
      • mikcatta
        • Nov 2014
        • 7
        Ta, thanks.
        Anywhere in the UK that supply them?
        • thstuff
          SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
          by thstuff
          This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
          Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
          1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
          2) Waited 30 seconds, then pressed remote Power button and "Select language"...
          01-30-2023, 05:01 PM
        • JUCaESAl
          Sony bravia KD-65AF9
          by JUCaESAl
          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
          10-20-2025, 04:03 AM
        • reporter1979
          Sony Bravia KDL-40W2000 flashing
          by reporter1979
          Hello all!
          A lightning burned this TV, Sony Bravia KDL-40W2000 that shows the 3-flash error code.
          I have read old threads here about this issue and I'm writing this just to ask an advice.
          First I replaced the power supply board (25€) just to discover that the issue remains. Now I have the option to replace the mainboard too (the one with HDMI ports) for another 40€.
          Considering I'm not a professional technician just an enthusiast, what would you do? Thanx in advance.
          02-07-2023, 09:26 AM
        • alegatorul
          sony bravia kdl-43w756c, no power, no sound
          by alegatorul
          the charger brick has 19,2-19,3 vcc
          changed the inverter board same result.
          where should i start?
          cheers
          11-15-2025, 10:00 AM
        • Aramis76
          Sony Bravia KDL-65W850C Red blink 6 times
          by Aramis76
          Hello all!
          New member here!
          I'm trying to see if this can be an easy fix, so far i found the service manual and followed the troubleshooting path a bit.
          When I power on the TV, i see "SONY" quickly flash but then it goes back to black. The power light flashes white a few seconds and then red for 6 blinks.
          The troubleshooting path had me check the BL_ERR signal and I have 3V so well above the written 1.9v threshold.
          Then I verified the Out1 and Out2 voltage and that's where i'm stuck.
          When I power on the...
          09-12-2022, 12:10 PM
