Sony Bravia KDL-40W2000 flashing
  • reporter1979
    • Feb 2023
    • 11
    • Italy
    Hello all!
    A lightning burned this TV, Sony Bravia KDL-40W2000 that shows the 3-flash error code.
    I have read old threads here about this issue and I'm writing this just to ask an advice.
    First I replaced the power supply board (25€) just to discover that the issue remains. Now I have the option to replace the mainboard too (the one with HDMI ports) for another 40€.
    Considering I'm not a professional technician just an enthusiast, what would you do? Thanx in advance.
  • nomoresonys
    • 12328
    • U.S.
    Re: Sony Bravia KDL-40W2000 flashing
    worth a shot, a lightning strike usually takes out one or the other sometimes both, 40 isn't real low but if you really like the tv, why not, go for it, should fix the problem.
    • cheeky2
      • Dec 2012
      • 339
      • uk
      Originally posted by reporter1979
      Hello all!
      Download the service manual for your TV and find out what the 3 flash error code relates to. It should highlight where the fault is located.
      • JUCaESAl
        Sony bravia KD-65AF9
        by JUCaESAl
        Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
        Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
        10-20-2025, 04:03 AM
      • PopsCaps
        Sony Bravia KDL-40V2500 that will not power on
        by PopsCaps
        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
        I do not hear any sound and I cannot see any backlight.
        I have tried disconnecting every cable on each board one at a time to see if anything changes.
        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
        03-25-2025, 11:23 AM
      • alegatorul
        sony bravia kdl-43w756c, no power, no sound
        by alegatorul
        the charger brick has 19,2-19,3 vcc
        changed the inverter board same result.
        where should i start?
        cheers
        Yesterday, 10:00 AM
      • stav242
        Sony KD-55X8509C white flashing/pulsing LED
        by stav242
        I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
        On inspection, there was no physical issues.
        I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
        - this seems to indicate repairing required, done by Firmware update.
        so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
        Inserted the drive and repowered the TV.
        LED changed to white flashing/pulsing ... and it sat there for over an hour.
        i was unsure what was happening so repowered the TV and now it just...
        01-08-2024, 07:39 AM
      • justin35
        Sony bravia kdl-43w755c - boot loop
        by justin35
        i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
        from what i read online it looks to be an emmc issue…
        i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
        i took out the board and say an samsung 16gb emmc
        i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
        i could try to put one instead of the 16gb one, but will it work?
        where do i get the software from?
        any help will be much appreciated!...
        03-06-2024, 12:26 PM
