Sony Bravia KDL-40W5500 led flashing 13 times
  • mikcatta
    • Nov 2014
    • 7
    Hi
    I understand from reading other forums that this could be down to a faulty CCFL tube.
    Is it possible to purchase replacement tubes?
    Regards
  • Ralph Green
    • Feb 2013
    • 66
    Re: Sony Bravia KDL-40W5500 led flashing 13 times
    Yes, you can buy a new tubes.
    • tibimakai
      • Jan 2012
      • 3680
      Need to measure the glass length and look around here: http://www.ccflwarehouse.com/
      • mikcatta
        • Nov 2014
        • 7
        Ta, thanks.
        Anywhere in the UK that supply them?
        • thstuff
          SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
          by thstuff
          This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
          Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
          1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
          2) Waited 30 seconds, then pressed remote Power button and "Select language"...
          01-30-2023, 05:01 PM
        • reporter1979
          Sony Bravia KDL-40W2000 flashing
          by reporter1979
          Hello all!
          A lightning burned this TV, Sony Bravia KDL-40W2000 that shows the 3-flash error code.
          I have read old threads here about this issue and I'm writing this just to ask an advice.
          First I replaced the power supply board (25€) just to discover that the issue remains. Now I have the option to replace the mainboard too (the one with HDMI ports) for another 40€.
          Considering I'm not a professional technician just an enthusiast, what would you do? Thanx in advance.
          02-07-2023, 09:26 AM
        • Aramis76
          Sony Bravia KDL-65W850C Red blink 6 times
          by Aramis76
          Hello all!
          New member here!
          I'm trying to see if this can be an easy fix, so far i found the service manual and followed the troubleshooting path a bit.
          When I power on the TV, i see "SONY" quickly flash but then it goes back to black. The power light flashes white a few seconds and then red for 6 blinks.
          The troubleshooting path had me check the BL_ERR signal and I have 3V so well above the written 1.9v threshold.
          Then I verified the Out1 and Out2 voltage and that's where i'm stuck.
          When I power on the...
          09-12-2022, 12:10 PM
        • stav242
          Sony KD-55X8509C white flashing/pulsing LED
          by stav242
          I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
          On inspection, there was no physical issues.
          I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
          - this seems to indicate repairing required, done by Firmware update.
          so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
          Inserted the drive and repowered the TV.
          LED changed to white flashing/pulsing ... and it sat there for over an hour.
          i was unsure what was happening so repowered the TV and now it just...
          01-08-2024, 07:39 AM
        • justin35
          Sony bravia kdl-43w755c - boot loop
          by justin35
          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
          from what i read online it looks to be an emmc issue…
          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
          i took out the board and say an samsung 16gb emmc
          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
          i could try to put one instead of the 16gb one, but will it work?
          where do i get the software from?
          any help will be much appreciated!...
          03-06-2024, 12:26 PM
