Vizio M470SL Issues
  • Audioplus
    • Feb 2012
    • 157
    Vizio M470SL Issues
    This one is driving me nuts! Unit powers up with remote and manually. I get the backlight, no picture or menu. I've replaced the Power Supply and been through 2 Main Boards (I'm suspecting that the main board may be faulty). I am now going to try a LED Driver, but really don't know how that could be the issue.
    Should I try another PS, or try a Main Board? None of the regular suppliers have Main Board's available so I do believe it could be faulty, maybe try a 3rd?
    Does anyone know how to access firmware for Vizio? I would like to try a new firmware download?
    Re: Vizio M470SL Issues
    How about the T-CON board? Or it is one of those panel with integrated T-CON?
    'I get the backlight' That means the backlights circuits and lights are OK.
    • joby91
      SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
      by joby91
      I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
      I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
      I found one chat about firmware on ************** forum but i cannot read the comments.
      https://**************/forum/108-114100-1#880537
      09-04-2024, 01:34 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • duwane
      A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
      by duwane
      Hi All.
      Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
      The issue:
      Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
      10-26-2022, 07:02 AM
    • GardevoirForEver
      Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
      by GardevoirForEver
      I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
      Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
      The motherboard of my ASUS...
      Yesterday, 04:30 PM
