Samsung ue46c6530
  • sordids999
    • May 2013
    • 2155
    • uk
    Samsung ue46c6530
    Hi guys
    got this tv but upon powering up the psu is just constantly clicking
    12 Volts = 0.00 DET = 5.3 Volts
    12 Volts = 0.00 BL = 0.00
    12 Volts = 0.00 PWM = 0.00
    GND HSY = 0.00
    GND GND
    5.3 Volts = 3.0 GND
    5.3 Volts = 3.0 5.3 Volts =3.0
    AMP SB = 5.3 Volts
    AMP PS = 0.00 then 1.2 Volts upon clicking psu
    thanks
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Samsung ue46c6530
    Checked the 3 fuses on the power supply?
    • sordids999
      • May 2013
      • 2155
      • uk
      yes selldoor there all fine
        Hmm, only 3V on the 5.3V rail. Try with main board disconnected.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Too big a set for me I can ask easy questions though?
          Can you establish where the click comes from. does the power led go on and off at the same time. What is the voltage on the BIG caps and does it vary with the clicks?
          • sordids999
            • May 2013
            • 2155
            • uk
            main board disconnected 5.3v rail is 0.00 volts
            main 450 volt caps are 0.00
            picture attached showing where clicking noise is coming from
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              More likely the black box at the end of the board just outside the red circle - looks like a relay? On the end of the heatsink looks like a 4 legged component - is that the bridge rectifier. The two outer pins should be around 300 vDC and the two inner pins 240vAC
              can you test there?
              • sordids999
                • May 2013
                • 2155
                • uk
                yes its the bridge rectifier
                inner pins 83 volts AC
                outer pins 0.00 volts
                  Do you see a BN44-###### number on the power board?
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Bn44-00357b
                    • sordids999
                      • May 2013
                      • 2155
                      • uk
                      BN44-00357B tom
                      • tibimakai
                        • Jan 2012
                        • 3680
                        From my experience, is the mainboard turning on and off. I have a 40C6300 doing the same thing. Mainboards are over $130.
                        I had two 46C6300 before, with the same issue, just slower clicking.
                        Usually, I remove the PS_ON wire from the connector and measure it, to see if it turns on and off.
                        On the old A series, I remember there it was a bad SMD capacitor causing this issue. I'm wondering, if it's not same or similar cause with these models too.
                          Possibly useful -A variant:
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            I wouldnt have thought that was correct? or the bridge is dead as if you have
                            83 on the inside you should have something on the DV.
                            With the power off can you ohms test the bridge.
                              Were you measuring the AC Voltage at the two inner pins of the bridge rectifier when the RELAY RL801 is clicking? If that is the case then the Voltage reading will not be correct.
                              • sordids999
                                • May 2013
                                • 2155
                                • uk
                                yes i measured it while the psu was clicking
                                so whats the other option of doing it ?
                                thanks
                                  Right now I would concentrate on as to why you are only getting 3V instead of 5.3V to run the main board. 3V is not enough to run the main board. The PS_ON signal is probably going up and down like crazy and that is why the power relay is clicking on and off, that relay supplies AC to the bridge rectifier.
                                  • sordids999
                                    • May 2013
                                    • 2155
                                    • uk
                                    ok thanks so whats the next option regarding testing the psu ?
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      Can you find a pin on any of the sockets marked pson/ pwron/ pwr the board descriptions for the sockets seem to be covered by labels!!
                                      Try to find the voltage regulators on the main board - picture is not really clear enough.
                                      I can make out one on the right hand side of last pic just to the left of the tuner box
                                      has a (backwardC ll) on it and 1117 - there is another ,I think between the two sockets
                                      below that.
                                      • sordids999
                                        • May 2013
                                        • 2155
                                        • uk
                                        ok ill check i found a bulged cap but changed it but still the same
                                        it seems these power units are failing alot
                                        http://www.ebay.co.uk/itm/SAMSUNG-LE...item25849188d5
                                        hes already sold 9
                                        ill update if i find the pson/ pwron/ pwr
                                        thanks
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
