Just a question before I buy a new one. I have a JVC model HR-XVC26U. The DVD drive in it is almost dead. Where can I by a new DVD drive for it. I took a look in it yesterday and the drive is a plastic vantastic POS. It may be part of a cheap PC drive made by JVC but I don't have any idea which one it would be. Is it even worth it to fix it? I can get another new junk unit at walmart for less than $80.00.
DVD/VCR Combo Unit
DVD/VCR Combo Unit
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
"I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
John Paul Jones
There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
Rod SerlingTags: None -
Re: DVD/VCR Combo Unit
I'll reply to my own post! My friend has the exact same unit with a pile of DVD's loaded at the same time by a four year old. I guess I'll unload that unit and try it because its free. If its busted too there just might be enough DVD drive parts to fix mine. I hate junk made in China!"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod Serling -
If the laser is not reading well, it is probably dirty. If dirt is not the problem, sometimes you can turn up the current adjustment pot on the laser just a tiny hair, and it will work again.
This makes me want to dig up my old Luxman CD player and get it running again. Would make a good Ebay piece if I can get it to work. Then again, even higher end CD players are all but worthless these days.Comment
No this drive has a simple problem. The tray loads, but it fails to kick the spindle. A micro switch isn't doing what it should. The drive is made of hermeticicaily sealed plastic so its very hard to fix. I have a good part number for buying a new DVD drive for it. This POS costs $80 bucks! I only gave $65 for the unit when brand new! This is just another POS from China that needs to die. Now the other unit just like this one that the four year old put a pile of disks in the tray at the sametime I just may save. Its easy to remove the cover, and backside unload any player.Beer is Good!
Mark Twain
John Paul Jones
Rod SerlingComment
Just send me that Luxman. It will be fixed Mate!"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
The worst part is, It's probably all banged up by now, being stored under the shelves at work for years. I don't remember the model number, but it starts with a D-something I think. Maybe D-380? I'll have to dig it out tomorrow.
It has a silver front panel and a really big disc tray that has the entire drive mechanism in it. It doesn't read most discs, and back when I was a dumb kid I messed with some adjustment potsComment
Got it out, it's a D-405. Still looks pretty good too. Another project to add to my listComment
Yes I had one of the first Pioneer Home CD players in my system. It always worked. Everytime that I looked into upgrading this old unit the specs of the newer ones didn't even come close to matching my old dog. At the time I worked at my buddy's auto bodyshop, and the CD player on the shop system died so I took the old Pioneer to work. It lasted all of a month and the sanding dust killed it too. I put it in the trash bin. I bet a good blowing out with canned air would have fixed it up."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
by federalhouseHi everyone,
I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
**Background:**
I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
**What I've Tried So Far:**
1. I accessed...1 Photo -
by perfm2So I've worked on dozens of HP and Dell laptops and have never encountered this before.
Steps taken in my usual process.
Reset security settings in the BIOS
Ensure existing HD comes up into the OS
Shut down the laptop and disconnected the main battery
Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
Replace battery connector and close up the laptop
Insert my USB drive with my Windows 10 image I've... -
by m710q_flashI had been using this hard drive for a while, and it worked fine only going back and forth between 3 computers.
Plugged it into an older computer that happened to have a really loose USB port. Light flashed once and died, never to be powered up again. Not sure if it's relevant that the USB port was loose.
Anyway, now it doesn't power up at all, it's been sitting on my desk for years and figured what the heck, nothing to lose as I'm not going to pay someone to fix it, maybe I can learn something from it.
Removed the case, figured I would look for anything... -
by abajorI was wondering if there is a knowledge base on troubleshooting HDD failures and when it might be viable to try certain repair/recovery techniques.
I recently got a WD20EARS 2TB Drive from a customer in hopes of retrieving data. The drive reads as zero size, I can't hear any head activity but it does appear the platter is spinning I can feel some gyroscopic action picking up the drive.
As a shot it the dark I bought a donor board and swapped the rom chip. Same issue zero byte drive.
I'm assuming that the armature is no longer functional internally so no data can...-
05-18-2024, 08:35 PM -
i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...-
- Loading...
