possible timing control fault with Samsung LE37M87BD
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    hi guys i had a problem with a Samsung LE37M87BD where it was coming on etc but colours where all inverted and stuff so i have had this issue with samsung before with the AS-15 chips on the Tcon so decided to order a new Tcon board, i replaced last night and it is still doing the same thing. could this be a faulty Tcon again as seller advertised on listing that it was confirmed working ?
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Re: possible timing control fault with Samsung LE37M87BD
    also when tv screen is supposed to be black or blue (cant remember) ie if you unplug source while on that channel the screen goes yellow.
    • sordids999
      • May 2013
      • 2161
      Have you tested the Tcon Board test points ?
      • selldoor
        Slow Learner
        • 7870
        If the source is hdmi you will wreck the hdmi controller chip doing that.
        It is not pnp.
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          ahh ok selldoor thanks for the info i didnt realise that. do that all the time aswell.... and i will test Tcon board points and post results later, thanks
          • mmartell
            • Oct 2013
            • 3189
            It is not pnp.
            Hdmi has hot swap detect so why do you say that you can't or shouldn't do it ?
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              It is not pnp.
              err, i beg to differ.
              HPD
              The HPD (Hot-Plug-Detect) feature is a communication mechanism between a source and a sink device that makes the source device aware that it has been connected/disconnected to/from the sink device. When an HDMI cable is inserted between the two devices, the resulting hot-plug detection instantiates a start-up communication sequence. The EDID information stored in the sink device gets read by the source device though the DDC bus, and the source device typically presents itself on the CEC link and requests basic status information from the sink device such as its power status as well as other devices on the HDMI chain.
              http://www.ni.com/white-paper/12680/en/
              Follow the white rabbit.
                HDMI is plug and play. One of my jobs at work is to hot-plug set top boxes on as many TVs as possible.
                @Mikey, I doubt the seller ever tested their boards. This fault is so common that someone may well have smashed their TV over it, hence the faulty board.
                • selldoor
                  Slow Learner
                  • 7870
                  Is that to retrotest if the plug and play works?
                  http://www.google.co.uk/url?url=http...oK3RcC828kbwXA
                    Yes all our boxes work plug and play. I tested nearly 25 the other day, Samsung 4K 55" LCD to 16" 720p off-brand Technika one. They all worked. They also survive very high ESD events.
                    • selldoor
                      Slow Learner
                      • 7870
                      Ok - maybe the hdmi spec has been improved on both TVs and sources
                      and on cables. Me - luddite - dont trust them
                      @Goontron - you are assuming manufacturers adhere to the specifications and controls.
                      There is one manufacturer in the UK/Europe who seem to send stuff out to the unsuspecting public
                      for testing
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        for testing
                        everything i have seems to comply. both HDMI capable graphics cards i have, my DVD and blu ray player, TV, sound system, etc. all comply. maybe a different story in other parts of the world though.
                        • howardc64
                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                          by howardc64
                          • Prior owner tried a replacement main board. No difference.
                          • Samsung 2x red blinking standby LED = panel fault
                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                          07-19-2025, 10:54 PM
                          09-07-2024, 05:50 AM
                        • vincentedel
                          Samsung SyncMaster 740n Phase Control Issue
                          by vincentedel
                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                          04-22-2025, 12:33 AM
                          09-06-2024, 11:40 PM
