LG inverter pair 6632L-0450A/6632L-0451A - slave misbehaving 2sec2black
    Ok, had this one on the bench for a while. Toshiba 42" LCD, but that's not really important. Got it as a freebie, it's been on the back-burner for a bit.
    Has the common LG-Philips 6632L-0450A/6632L-0451A inverter set on the LC420WX7 panel (720p 42")
    Originally, slave had blown BD9897FS chip (a very common fault). Replaced chip & set fired up with backlight... but it had 2 secs to black fault. I checked the bulbs with the help of a friend, taking the whole panel apart. All bulbs lit up perfectly for those 2 seconds, and there weren't any signs of shorts/arcing on the bulbs or bulb ends.
    Out of curiosity I bridged the timer capacitor on the master - no difference. I then did the same on the slave - the backlight stayed on. So, for some reason the slave is shutting down the backlight.
    Using my scope I checked the master and slave waveforms, and there is a difference. The master has a duty cycle which ranges from about 0% to 20%. Whereas the slave varies from about 20% to 40%. It's almost as if the slave has a kind of DC-bias to it. So I decided to measure the 24V current. At 100% brightness, the current is more or less identical - 3.24A vs 3.85A - within margins of error for transformers, bulbs and PWM settings. However with the backlight brightness set to 0/100 (effectively 50%, the lower 50% being inaccessible to the user) the 24V currrents are 1.78A and 3.91A - the slave current does not reduce!
    The other odd thing: The inverter seems to occasionally get stuck in a kind of "soft-start" mode, where it'll buzz slightly louder than normal although the backlight brightness is ok - it's something that happens when it first turns on normally, but it seems to also happen occasionally when it's running.
    Has anyone seen anything like this? The slave board is cheap - but it feels like giving in to just replace it!
  • x_orange90_x
    Vizio E55-E1 bad backlights or bad inverter?
    by x_orange90_x
    I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
    I don't know how exactly to test the inverter itself. Is it...
    01-29-2025, 09:24 PM
  • Gentian
    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
    by Gentian
    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
    03-06-2023, 07:07 AM
  • valvashon
    Insignia NS-LCD19-09 (PS OK, Inverter problem?)
    by valvashon
    For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
    History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
    01-04-2024, 01:44 PM
  • eccerr0r
    A modified sine wave inverter + a grid tie inverter?
    by eccerr0r
    If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
    Next thing is trying to charge the batteries using solar power, but that's another issue ...
    08-31-2023, 09:14 PM
  • caseyjay_48
    Sony KDL-46BX450 Inverter Troubleshoot Logic
    by caseyjay_48
    I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
    I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
    09-23-2022, 08:08 PM
