philips 42pfp5532d/05, error codes ?
  • finntricky
    • Jan 2014
    • 449
    • uk
    hi guys.
    just got hold of this 42"plasma,
    pluged it in, and get standby light, this flashes twice, then goes off, then repeats,
    turned it on and got blue light for around 3 seconds and goes back to flashing red stand by, as above.
    is this a error code ?
  • finntricky
    • Jan 2014
    • 449
    • uk
    Re: philips 42pfp5532d/05, error codes ?
    update, had the back off, 6 really bad caps on power supply,
    now all 6 replaced and still doing the same thing,
    disconnected the x and y and still the same, so another issue on power supply,
    time to get the meter out
      I had one of these doing similar - blown fuse on power board. No shorts found, so I replaced it and it's been perfect ever since.
      • finntricky
        • Jan 2014
        • 449
        • uk
        just had another quick look at this, just found out that 2 flashes of the red standby light indicates error on 12v rail,
        also checked va and vs, these are very bad, va = 8volts vs = 15 volts, so i think i'll give up with this one for now, as don't seem to have the time.
        as a side note, i unpluged the t-con but left everything else connected and the tv turns on with blue on light, but no volts change.
        any ideas ?
        • michalk3777@gmail.com
          Sharp Hisense - LC-65N7004U Error codes
          by michalk3777@gmail.com
          Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
          Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
          Regards,...
          12-15-2024, 09:20 PM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          Replaced emmc.
          Terminal log
          UART
          AC_ON
          E-B
          FDE enabled
          06-01-2025, 02:11 AM
        • Maalobs
          Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
          by Maalobs
          I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
          The relevant service manual for the chassis is available here.
          The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
          When I short the SDM to ground I get the layer-2 error code 53.
          The inside of the TV has no damaged components and no swollen capacitors.
          In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
          04-02-2019, 01:15 PM
        • mecha1166
          QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
          by mecha1166
          I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
          03-28-2024, 08:31 AM
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          Today, 08:49 AM
