Celsus dled39167fhd
  • sordids999
    • May 2013
    • 2161
    Celsus dled39167fhd
    hi guys
    got this tv today its a strange one if i plug in the scart lead and then plug in the tv to the mains its totally dead !
    but if i remove the scart lead then plug in the tv to the mains the tv turns on and then works fine once i plug in the scart lead again
    anyone seen this fault before ?
    ill update pictures soon
    thanks
  • sordids999
    • May 2013
    • 2161
    Re: Celsus dled39167fhd
    pictures updated
    update: tv turns on fine if i use hdmi lead
      Try just flexing that portion of the board as if you were to plug it in. Does it matter if the other end of the SCART is connected?
      • sordids999
        • May 2013
        • 2161
        tried flexing the board but nothing tom and i disconnected the other end of the scart lead from the virgin box but still nothing
        • Agent24
          I see dead caps
          • Oct 2007
          • 5036
          • New Zealand
          What if you try a different SCART lead?
          You said HDMI works, did you try all the other inputs? Do you get the same problem with any other analogue inputs?
          -David VanHorn
          • sordids999
            • May 2013
            • 2161
            yes i tried another scart lead but still the same and yes hdmi works fine plus i dont have a tv aerial to test only virgin media box,its a strange one with the scart connected the tv is totally dead but turn on the tv without the scart its fine then u can input the scart and watch tv
              I have to ask, does anyone really use SCART any more?
              I don't even advertise my TVs as having them - I have no way to test them. None of my equipment has SCART ports on it any more. It's a horrible connector. It always falls out, never seems to be seated well and the picture quality is dreadful. SCART is France's revenge for some prior misdeed.
              In the Vestel service menu, maybe see if there's an option for Pin8 SCART control? Some VCR/DVD players can control TV power via SCART.
              • sordids999
                • May 2013
                • 2161
                yeah i totally agree with what your saying tom but normally when i get tvs to repair i always check all connections are working hdmi,scart etc hence the fault i found just didnt want to look a idiot if i sold it on
                thanks
                • edugimeno
                  Fancoil.controller with current issues
                  by edugimeno
                  Hi there! One friend called to say his fancoill (used for a main access cold Air courtain) controller caught fire, and asking if I could recover the half burnt board
                  He said the design was too bad as this thing was probably designed for hot water only, as the board was places right underneath the condenser radiators
                  I found some burnt traces and after a quick Google search for the board name (Pwr-05v-w) I could see an image of the original I was able to find where the original traces were going
                  The scheme seems simple, from what I understand mains gets into the while 3 lead...
                  07-26-2024, 01:02 AM
                • stav242
                  Samsung BN44-006056A Blowing Mains plug fuse.
                  by stav242
                  ive picked up a Samsung UE32F5500AK TV with a BN44-006056A power pcb.
                  It was reported as `blowing the fuse` - the 3A one in the plug.
                  on quick inspection of the power pcb, a ceramic capacitor CM802 has blown apart.. photo attached.
                  Ive found a PDF of the circuit schematic and can identify the neighbouring components (RM801, RM802) but cannot find CM802 on the schematic.
                  Can anyone identify what CM802 is ?
                  thanks.
                  S....
                  12-30-2021, 10:45 AM
                • sew333
                  Can i plug pc on this apartment with older fuse box?
                  by sew333
                  Hello. I will be buying new apartment to live. But fuse box is older. Not the newest.
                  And my question. It will be fine to plug pc in this new apartment with that fuse box,i think it is aluminium,right?
                  PC WILL BE: Rtx 4090,14900K,1600W PSU
                  It looks like this ( screen from internet ). Looks like this,not sure i dont take a pic from there. Can i plug pc with that one?
                  screen of this:
                  room:
                  Someone said this to me.
                  1
                  "I would get advice from a local electrician...
                  03-29-2024, 05:37 PM
                • Stephen
                  MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                  by Stephen
                  MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                  03-15-2024, 09:37 AM
                • repair-it
                  Need advice testing a samsung power supply board with scope
                  by repair-it
                  I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                  07-12-2025, 11:00 AM
