Toshiba 37bv701b No sound
  • marty-clubber
    • Oct 2014
    • 58
    • u k
    Hi
    Have Tosiba 37bv701b Has no sound, know main board but has anyone fixed the problem component level?Board number 17MB65-1 20573482
  • Kilroys
    • Feb 2014
    • 70
    • Sweden
    Re: Toshiba 37bv701b No sound
    How about headphone.
    Sound ?
    • marty-clubber
      • Oct 2014
      • 58
      • u k
      There no sound at all mate
      • selldoor
        Slow Learner
        • 7870
        Tried other inputs? scart hdmi and outputs scart composite?
        Tried factory reset? Checked on osd that volume is high and not muted.
        Try muting/unmuting with remote. If speakers are socket connectors examine for bent broken pins. Check for cracked solder joints if soldered and around socket if socket.
        Picture is not good enough for troubleshooting does it show the audio chip and connector?
        • marty-clubber
          • Oct 2014
          • 58
          • u k
          Hi
          sound is working on the headphone tried factory reset no luck
          any ideas board 17mb65-v1
            Very common fault bad audio IC on main board requires good skill to replace but about £5 on eBay
            • marty-clubber
              • Oct 2014
              • 58
              • u k
              Thank you done a few ic chips willing to give it ago.
              can you post me a link to the part Tom
              thanks again
                I've never done one - Can't remember to be honest. If you search around you can probably find the repair kit for it. It's a common issue on 17MB62 and 17MB45, at least. Possibly on other models too.
                • marty-clubber
                  • Oct 2014
                  • 58
                  • u k
                  Unfortunately that chip not on my board model number 17mb65-1 v.1
                  post pic.
                  Also does any one know good soldering paste smd chips hot air gun.
                  rgs marty
                  • Charlie20v
                    • Nov 2014
                    • United Kingdom
                    Hi, did you ever solve this problem? I have the same problem on a similar board (17MB65-1 v.2) I'v found a replacement board for £45 but would rather have a go at replacing the audio IC. Where a bouts on the board is the chip? Thanks
                    • Charlie20v
                      • Nov 2014
                      • United Kingdom
                      http://www.ebay.co.uk/itm/17mb62-2-6...item232d1f194f
                      Is this the part? Can't seem to see it on my board...
                        Some boards do not have this chip if they are for smaller screen TVs. In which case the fault is probably different.
                        • marty-clubber
                          • Oct 2014
                          • 58
                          • u k
                          Hi solved the problem by doing factory reset, and manual scan for channels
                          then it worked.
                            then it worked.
                            This issue is intermittent fault. It's possible you accidentally fixed it and it will come back later. Did you thoroughly test after doing this? I would not expect that to fix it. Unless it was "TV Speaker" off in the user menu. Not sure if Vestel sets even support that.
                            • marty-clubber
                              • Oct 2014
                              • 58
                              • u k
                              Hi yes tested for few days now it is ok the tv i was working on was the Toshiba 37bv701b, Tv engineer told me on ebay
                              Factory reset in the service menu, Manual scan for channels.
                              • Trevtron
                                • Apr 2015
                                • 124
                                • Portugal
                                Old thread, I know, but '+1' for this method. I was dubious but it worked a charm.
                                • braincrush
                                  • May 2018
                                  • 3
                                  • United Kingdom
                                  hi gents, how do i access the service menu on 37bv701b please ? as i presume it's not the initial setup you're talking about right ?
                                    • 12079
                                    • U.S.
                                    See if this works: Be very careful in service menu, just try the reset, make note of settings before you change any so you can put it back if need be.
                                    This should be the one for lcd tvs.
                                    Press the {MENU} button on the remote.
                                    Highlight the "Picture" icon.
                                    Press the {9} {3} {0} {1} buttons on the remote.
                                    {OK} button will access/navigate through modes
                                    {VOL +}, {VOL-}, {P+} & {P-} buttons move through options and change values
                                    To exit, press the {MENU} button."
                                      • 12079
                                      • U.S.
                                      Another: press the "Mute" button twice on the remote control. Next hold the mute button down and press the "Menu" button on the TV set to launch the service menu. You can exit the service menu by turning off the TV set
                                        • 12079
                                        • U.S.
                                        A couple more:
                                        Press "Mute" & 'Menu" buttons on the remote control simultaneously.
                                        Press "Menu"' button on the remote control, and enter {4 => 7 => 2 => 5}
                                        Press 'Volume Down' button on the front panel of the TV and press and hold digit '9' on the remote control.
                                        OR
                                        With No Menu displayed on the panel, press 'AV" & "F' buttons simultaneously.
                                        Enter code {1 => 0 => 4 => 8} by the remote control.
                                          09-06-2024, 05:27 AM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                          09-06-2024, 05:59 AM
